MIR Racewear - LB
Ribtect - SS (non-flash)
What's the first thing you would change if...
Gary Kozuma2
PostPosted: Thu Aug 23, 2001 6:19 pm    Post subject: What's the first thing you would change if... Reply with quote
What's the first thing you would change if you had a lack of mid corner grip?
Gary K.
Jimmy Moore
PostPosted: Wed Sep 12, 2001 1:12 pm    Post subject: What's the first thing you would change if... Reply with quote
I would move the front wheels in one spacer and see what that does.
Keith Archambeau
PostPosted: Wed Sep 12, 2001 2:00 pm    Post subject: What's the first thing you would change if... Reply with quote
Change axel
Gary Kozuma2
PostPosted: Wed Sep 12, 2001 2:25 pm    Post subject: What's the first thing you would change if... Reply with quote
quote:
Originally posted by Keith Archambeau:
Change axel
Keith!
Hey thanks for all the help this past weekend. The #1 reason I bought an MBA from Tom is be in the "team". Look forward to talking with you some more in a couple of weeks. Hope all is well.
Gary Kozuma
Pete Muller
PostPosted: Wed Sep 12, 2001 6:12 pm    Post subject: What's the first thing you would change if... Reply with quote
Raise the seat (i.e. raise the CG in some way).
Jean Stafford
PostPosted: Thu Sep 13, 2001 7:25 am    Post subject: What's the first thing you would change if... Reply with quote
quote:
Gary K.
Me too Gary.
What class?
What Kind of Course?
Sprint or Road Racing?
Two or four cycle?
Which end is losing grip, front or rear? (Understeeer or oversteer)
All these things, and more, play a part.
Could very possibly be your driving style.
When you enter a corner too fast, late, hard, you set up a condition that will probably require you to correct for the back end trying to come out. When you do this, the inside rear tire sets down, or the chassis unloads. This will cause the car to push or understeer in the middle of the turn.
Entering more slowly, read that as delibrate, will load the chassis and raise the inside tire thus minimizing the tendency for the car to push. Maintaining this "loaded" condition will keep the tire on the inside rear, light. Anything that causes you to "unload" the chassis will change the handling in the middle of the turn.
I know this is the hardest thing to change, but I think it's very important to making the chassis work, whatever one you have.
Good Luck.
DB time: 0.130321 (41.08%), total time:0.317242, queries:37
