SKUSA (non-flash) - LB
MRP - SS
What's the first thing you would change if...
Gary Kozuma2
PostPosted: Thu Aug 23, 2001 6:21 pm    Post subject: What's the first thing you would change if... Reply with quote
What's the first thing you would change if you had a lack of mid corner grip?
Gary K.
code
Quote:
Glenn Holland
PostPosted: Thu Aug 23, 2001 8:46 pm    Post subject: What's the first thing you would change if... Reply with quote
At what end of the kart?
Rick Blood
PostPosted: Thu Aug 23, 2001 9:08 pm    Post subject: What's the first thing you would change if... Reply with quote
With Gary it's probably his grip on the steering wheel
Gary Kozuma1
PostPosted: Fri Aug 24, 2001 7:41 am    Post subject: What's the first thing you would change if... Reply with quote
quote:
Thanks Glenn,
At the rear.
And Rick, it's not my grip on the wheel, it's more like my grip on reality!
Gary K.
Mark Dismore Jr
Advertiser
Advertiser
PostPosted: Fri Aug 24, 2001 1:07 pm    Post subject: What's the first thing you would change if... Reply with quote
quote:
Originally posted by Gary Kozuma, Vista CA:
Thanks Glenn,
At the rear.
Gary K.
Longer rear hubs, stiffer rear axle, put in rear bar (if available), add seat struts to hanger, narrow rear, that's a start.
Mark
Comet Kart
Tim Blaney
PostPosted: Fri Aug 24, 2001 1:36 pm    Post subject: What's the first thing you would change if... Reply with quote
quote:
Originally posted by Michael Taksa:
I usually finish last, well once I did, and got lapped, what should I change???
I only raced once BTW, this weekend would be my second time.
Michaal. might I sugest you drive faster?
Sorry, couldn't resist. Practice, practice, practice is the key.
Michael Taksa
PostPosted: Fri Aug 24, 2001 1:42 pm    Post subject: What's the first thing you would change if... Reply with quote
Thanks Tim, My original message was a little sarcastic I know I should practice.
Also if I drive faster I wipe out
I guess I can't win, And everybody else cheats This was a huorous remark too.
John Valerio
PostPosted: Fri Aug 24, 2001 4:13 pm    Post subject: What's the first thing you would change if... Reply with quote
code
Quote:
[/qb]
Gary,
The mid corner grip could be a number of things.. Most likely its driver technique If the kart is working every where else. I dont wanna tell you your driving needs help but I stumbled on a great article adressing this issue. Go to www.murphybros.com then choose the tech link. The article sheds alot of light on what a kart can and can't do with an emphasis on cornering......hope this helps
John Valerio
[ August 24, 2001: Message edited by: John Valerio ]
Michael Taksa
PostPosted: Fri Aug 24, 2001 10:10 pm    Post subject: What's the first thing you would change if... Reply with quote
John Denman
PostPosted: Sat Aug 25, 2001 8:01 am    Post subject: What's the first thing you would change if... Reply with quote
How soft/stiff is the axle?
How much castor do you have?
Is it both left and right turns mid corner oversteer?
Are you braking into the turn at all before it looses grip?
Does the grip return on throttle or widening the turn radius?
Gary Kozuma2
PostPosted: Sat Aug 25, 2001 8:46 am    Post subject: What's the first thing you would change if... Reply with quote
quote:
Originally posted by John Denman:
How soft/stiff is the axle? It's a "medium" axel. We've tried the hard but that gave unpredicatble results.
How much castor do you have? This is an 80 with straight pills. This is one of the next steps.
Is it both left and right turns mid corner oversteer? It's more of a slide at constant steering input and throttle verses a steering induced slide.
Are you braking into the turn at all before it looses grip? Yes. Mostly the guy runs at Amago which is almost all cut and thrust.
NO!
Thanks John,
Gary K.null
DB time: 0.154504 (42.48%), total time:0.363693, queries:37
