MIR Racewear - LB
RLV - SS
Zip Kart ID Help
Goto page 1, 2, 3  Next
Craig Butt
PostPosted: Fri Feb 03, 2012 4:54 pm    Post subject: Zip Kart ID Help Reply with quote
I've always wanted a Superkart and I ran across this one in Michigan and drug it home as a project.
OK, I know it's actually a 125cc Superkart, but I could not find a photo of a Zip with the same bodywork. The rear wing a a late addition. The seller seemed to think it was mid '80's vintage. But can anyone get me a little closer on year and model of chassis? ALso, I understand Rotax built 124cc / 126cc motors both with rotary valves and reed valves - any insight on this one would be appreciated as well. Thanks!
http://www.flickr.com/photos/craig71188/sets/72157629162920277/
Craig Butt / Ohio Valley Region SCCA
2003 Italkart Supersonic / CRS (x2!)
Robert Lawson
PostPosted: Fri Feb 03, 2012 6:35 pm    Post subject: Reply with quote
Hey Craig.
Never thought I'd see that rig again!
I did the body for Brad Hunt, he owned it before your seller. It was once Dennis Berniers and maybe Greg Stamm before that.
It has a Swift nose, Anderson pods and I made the wing and airbox on the left side. It was a replacement for a similar kart that he had wrecked at Road America, that kart had the original Zip "batman" type 1 piece body. You can see them all day long on UK karting sites. Lots of them in older videos from over there as well.
Early to mid 80's for sure. It's definately vintage!!!!!!!
That was once Scotty Fieslers Rotax, I think it's a 129. Not sure Scott would remember either!!!!
Heard a story that that kart was put out to pasture.....literaly. A farmer bought it and was running it around the yard, up and down a dirt road......
Hey, it's still in 1 piece! Laughing
Ian and Sam will be able to ID it for ya.
RPM
John Benson
PostPosted: Fri Feb 03, 2012 6:44 pm    Post subject: Reply with quote
Hi Craig,
I can't help much on the Zip, but the motor is a 128 with a "GP" cylinder . I can't see if it is a side load gearbox , but if it is ,it probably has a digital ignition also.Rotax went to the 129 -130 engines in 1993 (?) . Good motor, but hard to find parts for now , and apparently can't run with the newer Pavasi. JRB Very Happy
Ian Harrison
PostPosted: Fri Feb 03, 2012 7:15 pm    Post subject: Reply with quote
Hi Guys
Zip Bandit 1, I believe.
My first kart was a Zip Bandit 2, which was almost identical, except the diagonal tubes running forward from the front crossrail had splits in them and a clamping system, so that you could alter the chassis stiffness. Also the calipers of the Zip "self-adjusting" brake system on the 2 were black anodised not natural finish.
I'd agree with JB about the motor, it does have the Digital ignition and I would really like to own it!!
Trying to see the clutch levers. The red cable is a push-me-pull-you for the shift, 2 pedal for sure and an extra front rad Shocked
I just missed a kart with a Rotax 129 installed on UK Ebay a few weeks back(forgot and missed the finish time!!), and it went cheap Sad
Good luck with your restoration project and if you get fed up . . . . . Wink
Best Regards
Ian Very Happy
Ian Harrison
Viper Racing UK
www.viper-racinguk.co.uk
sales@viper-racinguk.co.uk
+44 7984 225 564
+44 161 343 2009
Craig Butt
PostPosted: Fri Feb 03, 2012 8:04 pm    Post subject: Reply with quote
RPM
"out to pasture" may be rather close to the truth. It was in a shed in rural Michigan. The owner said he bought it about 8 years ago +/- to "play with" with his kids. It mostly sat, but he didsay he had run it up and down the road here and in Colorado with some friends.
Thansk for the information - always like it when you can get a little history to go with the piece.
Craig Butt
PostPosted: Fri Feb 03, 2012 8:10 pm    Post subject: Reply with quote
Ian Harrison wrote:
Hi Guys
Best Regards
Ian Very Happy
Thanks Ian - the clutch on it currently is a hand clutch on the upright for the steering - I'll try to add a better picture later this weekend. I'll keep you in mind for the motor - not sure of the direction to take on this yet. I have considered taking one of my spare CRS ICC motors and building a Mod 125 ICC to play with... or build a 250cc something.... or restore what's there. Too early to tell, I need to get the sprint karts ready for this season before I can dig into this one.
Dennis Bernier
PostPosted: Fri Feb 03, 2012 8:17 pm    Post subject: Reply with quote
Craig,
This is originally a Zip Bandit kart which had a one-piece
body. It was purchased from Franklin Motorsports by Don Hupp
for his daughter Donna in 1986 and I bought the kart in 1988. I sold
the kart to Brad Hunt, I believe around 2003 and as Robert Lawson
mentioned, he built a newer and more attractive body for the kart.
Later on, Brad traded the kart to Harry West and was eventually sold
to a farmer. When I owned the kart, it had the Rotax 128 engine with
the GP cylinder, but I believe Brad Hunt swapped out the older 128
engine with a newer Rotax 129 digital ignition motor. Good to see
the kart again; restore it and put it back on the track. PM me, if I
can help.
shaun everard
PostPosted: Sat Feb 04, 2012 12:00 am    Post subject: zip bandit Reply with quote
Hey Ian just read ur post on the zip bandit are u still looking for one and does it have to be a bandit 1 or 2?? With or with out engine etc
Ian Harrison
PostPosted: Sat Feb 04, 2012 2:25 am    Post subject: Reply with quote
Hi Shaun
It's more the Rotax 129 that I'm looking for, but thanks anyway.
Hi Craig and you Guys,
I'm not an early Rotax specialist by any means.
I think that Craig's motor is a 128 from the non-watercooled crankcases and method of head cover retention.
If anyone wants a 129 Rotax parts book, I have it in PDF format. Just drop me your e-mail address.
Here's a couple of pictures of the inlet side of the 128 motor.
Here's a nicely refurbed 128 motor, with Aprilia/Rotax Max type pv bellows/piston and new VHSB silver top carb.
The only difference I can see between the motors above (apart from the spurious water position outlet on the head cover), is the design of the gearbox cover. Both are sideloaders. The lower engine shares the design of gearbox cover with the 129, so I'm guesing it's a later motor.
The 'U' shaped water pipe indicates the lack of crankcase cooling.
Heres an image of the 129 crankcases you can see the water inlet tube (item 5) on the bottom of the motor and see the detail of the internal waterways from the water pump up to the exhaust side of the cylinder.
Craig, a picture of the inlet side would be good!!
If you just look at the head cover, you will see that the head cover on the 129 is secured by bolts around it's periphary and the head insert is independantly bolted down.
Heres the 129 cylinder/head arrangement
This arrangement is also used by Aprilia GP and BRC (except they use 6-bolt insert fixing as opposed to the 5 bolt of the Rotax). See an excerpt from the BRC parts book below and an external image.
Anyone know anything more, I'm glad to hear!!! Cool
Now does anyone know if the 129 base stud pattern is the same as Aprillia and the current crop of watercooled crankcase tandem twins or is it the same as the non-watercooled Rotax. You can probably follow my train of thought!!
Best Regards
Ian Very Happy
Ian Harrison
Viper Racing UK
+44 7984 225 564
+44 161 343 2009
RUSSELL ANDERSON
Location: United Kingdom (Great Britain), NOT USA, CASTLEFORD
PostPosted: Sat Feb 04, 2012 4:24 am    Post subject: Reply with quote
Ian,
Rolling Eyes 129 Rotax: I have one at Castleford that I used to do all the work on our FPE cylinders and in particular the exhausts. Different pattern to the DEA. I have decked the cases to the same as a FPE but you are welcome to have a look.
Anderson Karts .....tried one yet?
www.andersonkarts.com
Robert Lawson
PostPosted: Sat Feb 04, 2012 7:56 am    Post subject: Reply with quote
Best Regards
Ian Very Happy
Ian, I'm sending you some pic's to post.
I did quite a bit of research for Harry West on upgrades for the Rotax. I found many good bits that bolt directly on that will add power and reliability. Ign, cylinders, heads, pistons, cranks, etc. all aftermarket late model stuff produced by Suter. This stuff may not be "new" these days but are one hell of an upgrade for that old model and brand.
The issue was cost. You can make a Rotax fly but it will cost more than it's worth.
Just a few months ago I sent Harry the info and cost........it got pretty quiet on the other end of the phone. Sticker shock I guess!!!!!
I saved the pic's but seem to have deleted the gents e-mail. He wanted 2,500 euro for the cylinder and head alone! Nice stuff though!!!!
RPM
Ian Harrison
PostPosted: Sat Feb 04, 2012 8:18 am    Post subject: Reply with quote
Hi Russell
Fancy that!!!
I'll certainly have a look and that was exactly my idea!! Makes things a lot easier that having to change 2 of everything all the time.
But was it the FPE cylinders for the watercooled cacrankcases or the FPE Rotax replacement cylinders that you used it for at the time?
The FPE watercooled crankcases have the same stud pattern as the BRC and Aprilia GP. I had assumed that the DEA would also be the same, but from what you say I am thinking that the DEA must use a unique stud pattern??
Something to chat about over a tea, the next time I'm over.
Anyway with the snow coming down hard, lets hope it clears up in time for testing on the 14th at Oulton.
Better see if I can get home!!
Best Regards
Ian Very Happy
Ian Harrison
Viper Racing UK
+44 7984 225 564
+44 161 343 2009
Riley Will
PostPosted: Sat Feb 04, 2012 9:16 am    Post subject: YOUR Reply with quote
Or you could do this:
Aprilia's last magnesium cased RSW with APF cylinder
Riley Will
BRC Engineering
rwill@brceng.com
(403) 216-0630 wk.
www.brceng.com
Ian Harrison
PostPosted: Sat Feb 04, 2012 10:01 am    Post subject: Reply with quote
Hi Riley
That would do nicely!!
Or equipped with one of these:
A snip at £3300.00 retail each plus tax. Thats $5200 USD per cylinder kit.
Best Regards
Ian Very Happy
Ian Harrison
Viper Racing UK
+44 7984 225 564
+44 161 343 2009
Craig Butt
PostPosted: Sat Feb 04, 2012 11:10 am    Post subject: Reply with quote
I posted up anothe half dozen pictures with some better views of the engine and the hand clutch - then realized they were not as high a resolution as the first ones. Hopefully it will let Ian see what he was looking for!
Page 1 of 3
DB time: 0.105649 (30.29%), total time:0.348776, queries:38
