KartSport North America - LB
K1 Speed - SS
Really Now, 15 Hours?
Aaron Smith
PostPosted: Wed May 15, 2002 2:29 am    Post subject: Really Now, 15 Hours? Reply with quote
I just put a new Raptor III in my kart, and will be running the box stock class. Briggs recommends 15 hours of break-in time. This is not realistic! How much break-in time is really required before you can run it under race conditions?
Rodney Ebersole
PostPosted: Wed May 15, 2002 5:12 am    Post subject: Really Now, 15 Hours? Reply with quote
Yes, plus it is unrealistic that you can take out of the box and race it. It should be taken apart and clearances double checked and everything retorqued. They sometimes come with missing or loss parts. For breakin just put 13 onces of 30 weight oil in it, fire it up on the stand and run it with out reving it up for 10 minutes, drain oil, let cool, fill it again and repeat, drain then fill and take it out and run it with out full sustained throttle. Once cooled retorque side cover and head bolts. fill it with your favorite oil and give it heck.
Stephens
PostPosted: Thu May 16, 2002 4:45 am    Post subject: Really Now, 15 Hours? Reply with quote
Buy a 2-Cycle
Dean Giles
PostPosted: Thu May 16, 2002 7:22 am    Post subject: Really Now, 15 Hours? Reply with quote
Good reply and great help Stephans.
Aaron Smith
PostPosted: Thu May 16, 2002 11:12 am    Post subject: Really Now, 15 Hours? Reply with quote
Stephens: It was a sincere question, and I was looking for a sincere reply.
If I was looking to race 2 cycles, I would be the only kart in my class around here. That's no fun, no matter how fast you're going.
Rodney, thanks for the tips. That's the kind of advice that us NEW karters need.
Todd Lamb
PostPosted: Thu May 16, 2002 12:57 pm    Post subject: Really Now, 15 Hours? Reply with quote
I can't imagine breaking in a Briggs for 15 hours....run it at idle for about 15 minutes, and then spend another 15 minutes revving it a little (1/8-1/2 throttle blips). Take it to the track after that and do 10 or so moderate speed laps.
Bring it in, change the oil, torque the head, and go racing.
FYI, on the blueprinted Briggs we rebuild them and race them - we never break them in after a rebuild.
Greg Keresi
PostPosted: Thu May 16, 2002 4:35 pm    Post subject: Really Now, 15 Hours? Reply with quote
If it's box stock...you will want to make sure you go thru the engine and make sure it's cleaned up inside. Have the clearances checked and all bolts torqued to spec. Just run the motor under light loads for 15 minutes like Todd said and change oil. Re-torque external head bolts and side cover for safe measure after it cools. good luck
DB time: 0.072127 (41.57%), total time:0.17352, queries:37
