KartSport North America - LB
MRP - SS
raptor III, fuel starve?
Gary Lawson
PostPosted: Sun Apr 14, 2002 6:46 pm    Post subject: raptor III, fuel starve? Reply with quote
Is the motor blueprinted? Are you running on gas or alcohol? when you say you think it is starving for fuel what is the motor actually doing, cutting out? What temp is the motor at and what jet do you have in the engne if it isn't stock.
Gary Lawson
dick pohlman
PostPosted: Sun Apr 14, 2002 10:27 pm    Post subject: raptor III, fuel starve? Reply with quote
I am new to 4 cycle racing. My grandson's new raptor III seems to starve for fuel at the end of the straights. Long before rev limits. Where do I begin to look.
dick pohlman
PostPosted: Mon Apr 15, 2002 3:19 am    Post subject: raptor III, fuel starve? Reply with quote
The engine is box stock running gas at this time but will be using alky. The engine just lays down and sounds to me like it is starving. I can't drive it, I don't fit. My grandson says that if he backs off the gas it runs better. Also, we have not yet installed the restrictor plate.
Rick Dunwell
PostPosted: Mon Apr 15, 2002 3:12 pm    Post subject: raptor III, fuel starve? Reply with quote
The engine is not "starving", it is actually too rich. Turn the adjustment screw "in" until it clears up. You may need to decrease jet size depending on your altitude. Once you switch to alcohol, the carburetor and engine will need to be totally reconfigured and blueprinted.
dick pohlman
PostPosted: Wed Apr 17, 2002 12:27 pm    Post subject: raptor III, fuel starve? Reply with quote
Rick,
You were right. I was too rich. Thanks for the help.
Rick Dunwell
PostPosted: Thu Apr 18, 2002 1:24 pm    Post subject: raptor III, fuel starve? Reply with quote
no problem...when you're ready to switch to alky, let me know.
DB time: 0.109885 (45.56%), total time:0.241175, queries:37
