Bondurant - LB
K1 Speed - SS
SCCA Enterprises - FB
Honda Engine Break-in
Gerry Harris
PostPosted: Tue Sep 25, 2001 8:43 am    Post subject: Honda Engine Break-in Reply with quote
I just had a Honda GX160 totally rebuilt (top and bottom end), my engine builder told me to break it in by doing 10 easy laps, oil change, then 10 agressive laps, oil change and it should be ready to go.
I did this, however the engine feels weak.
I used my regular oil (power plus, synthetic)
during the break in period, should I have used a non-synthetic to 'bed' the rings, can I change the oil to mineral at this point and
go through the break in cycle again?
Gerry Harris
gillickm
PostPosted: Tue Sep 25, 2001 11:46 am    Post subject: Honda Engine Break-in Reply with quote
Use a non-synthetic for your break in, so that your rings will seat properly.
Chad Stapleton
PostPosted: Tue Sep 25, 2001 2:18 pm    Post subject: Honda Engine Break-in Reply with quote
Ask your engine builder, but synthetic is not a good idea for break in.
Chad Stapleton
PostPosted: Tue Sep 25, 2001 2:21 pm    Post subject: Honda Engine Break-in Reply with quote
Stan Smith
PostPosted: Wed Sep 26, 2001 6:37 am    Post subject: Honda Engine Break-in Reply with quote
Yes you can! Be sure that your oil mixes with conventional oils, it'll say on the jug. Most of the so-called racing oils will not mix with real engine oil be it syntheic or conventional.
Funny how you can break in with racing oil but syntheic is too slippery?
Stan Smith
PostPosted: Wed Sep 26, 2001 6:41 am    Post subject: Honda Engine Break-in Reply with quote
Gerry.
I forgot, you say it seems weak. Have you done a leakdown test and a compression test? This is the only way to know if the rings and valves are up to it.
Gerry Harris
PostPosted: Wed Sep 26, 2001 7:22 am    Post subject: Honda Engine Break-in Reply with quote
Hi Stan
I have not done a compression or leakage test, guess its about time I did one.
Everyone, thanks for the feedback, much appreciated.
Gerry
Steve Clark
PostPosted: Wed Sep 26, 2001 12:08 pm    Post subject: Honda Engine Break-in Reply with quote
Gerry,
I tried to reply by using the e-mail link but for some reason I was not allowed. Who is your engine builder. I raced 4 cycle at Waterloo for a few years and had a great builder. I never had a problem with a break in. I always used Mobil 1 5/30. It did not carbon up the engine. Never used the fnacy cool power stuff. My builder never wanted me to use it. Always had a top 5 motor.
Steve Clark
PostPosted: Wed Sep 26, 2001 12:10 pm    Post subject: Honda Engine Break-in Reply with quote
Oh yeah. Another idea. How are your lap times with the motor? If you are quicker then I guess the motor is fine.
Saro Marcarian
PostPosted: Tue Oct 02, 2001 9:49 am    Post subject: Honda Engine Break-in Reply with quote
Most of the resons for not using a synthetic during break-in are co$t related... Do you want to spend large dollars on oil you're gonna toss after 5 minute's worth of running? Much of a synthetic oil's strength is related to LIFE.
As far as being a BAD choice TECHNICALLY, it's just oil. I doubt that it's BAD to break-in a motor with synthetic, though as I mentioned before, your wallett may disagree...
DO heed the don't mix warnings if they apply to your brand of oil...
-Saro
DB time: 0.083479 (44.45%), total time:0.187795, queries:37
