KartSport North America - LB
Russell Karting - SS
Franklin / Merlin USA - FB
Brief update on FJ spec motor proposal
Goto page Previous  1, 2, 3, 4, 5, 6
Richard Jung
PostPosted: Mon Jan 30, 2012 11:05 am    Post subject: Reply with quote
Sorry Robbie, didn't mean to discourage you. I wasn't there, so I don't know if the course favored karts, or other factors involved. Just prelim data. Hope to have first hand knowledge in a few weeks. Joe's findings sound promising, where the WF can pull clean, but is choked off at the top.
Joe Ricard
PostPosted: Mon Jan 30, 2012 12:20 pm    Post subject: Reply with quote
[quote="Richard Jung"]
Joe Ricard wrote:
Thanks for sharing the data Joe. I'm probably wrong, but I thought you'd be around the 315 lb range with a WF? Rick
Sorry Richard. I weigh 160 Plus the kart equals somewhere near your 315 estimation. Bottom line way more than the JB WF 255 lbs.
I was geared lower in the WF kart by a couple teeth compared to the Raptor which did briefly pull to 7300 RPM before it started acting up.
So it's not like the JB WF was too tall in the gearing. Torque was OK, kinda like a little tractor motor.
Still trying to line up some sprint track time where they can both go heads up
Arrow AX-8/ Rotax Sr.
Chris Teague
PostPosted: Mon Apr 30, 2012 7:46 pm    Post subject: Reply with quote
Joe Ricard wrote:
I don't think any of the FJ trophy winners were Autocross only.
I never realized the huge improvement a kid will get with a few lapping days at a sprint track. Since getting my youngin out to the sprint track he got considerably faster in the cone dodging gig.
Kevin Teague was 4th last year in FJA in Lincoln, and he has only done autocross. He would love to do some track events, but we just haven't had the time yet, and I'm sure it would help.
Joe Ricard
PostPosted: Tue May 01, 2012 9:23 am    Post subject: Reply with quote
Interesting this came back to the top.
Since Xmas we have been beating a rut in the road to the sprint track. My son has made comments to the effect that autocross is what he used to do.
There is a pretty strong group of Junior kart racers here and since the purchase of a used Mini Max he has been having a blast racing his friends as often as we can get to the track. 2X a month.
Something something about he doesn't have to chauk 500 cones at sunrise. Rolling Eyes
Would I like to get back to AX sure, but I suspect it will be when he gets a license. Thinking STS CIVIC??????
So to the point, get him seat time at a track and they may not want to go back.
Tom Reynolds
PostPosted: Wed May 02, 2012 12:51 pm    Post subject: Reply with quote
Keep watching fastracks for some comments about this original topic. While the KAC is limited is what we can comment on, I can tell you those that weren't on the KAC until this year now understand why the Spec Motor was being worked on as a possible path for the SCCA.
At this time, its possible and likely no change will happen (no spec motor for JA/JB) anytime soon due to letter writing against such a proposal in its current form - however this is of course very unofficial until you see it in a fastrack. What is certain and I'll risk commenting on is that nothing is changing for 2013 for JA/JB (minor weight changes excluded as those can happen anytime) as we will miss the deadline for 2013 rules next month.
Andrew Peppler
PostPosted: Wed May 02, 2012 8:16 pm    Post subject: Reply with quote
Congrats needs to go out to everyone involved with getting a proper slide restrictor made for JB! I think this now makes the WF a great option in JB. I can now say if anyone asks me "what engine would be best for my son/daughter", the WF would be first reply to non-karting families since it really is the easy button.
We are still running the KT100, but I am starting to look at the WF as a possible option for next year. I expect we'll see a lot more WF's in action soon.
Good job to everyone!
Robbie Nelson
PostPosted: Mon May 07, 2012 5:11 am    Post subject: Reply with quote
After spending yesterday running (yes, running) cross course most of the day (seemed like most of the day) with a lead battery starter to refire the KT100, I now want an easier to start engine. I imagine a WF would fit that bill. Can someone point me in the right direction?
What will I need to convert from a KT100 to a TaG WF? Is there anything I need to be aware of? Perhaps someone could start a "Briggs WF FAQ" thread.
Brian Garfield
PostPosted: Mon May 07, 2012 6:06 am    Post subject: Reply with quote
I will comment that the WF is absolutely the best motor for JB drivers (not to mention the power advantage it now has), and anyone that can afford to switch should.
That said, you should be prepared to shell out some cash. Since before the KAC started talking about spec WF's, I researched the motor and the costs to change as well as checking on EKN for used or nearly new motors. There's about 1 WF for every 100 KT's (not an exaggeration) and the used ones are often illegally (for SCCA) modified or just sketchy IMO.
So, more than likely you'll be starting out with a new one, which IMO is the best option anyway if you're going to use this for JB and JA anyway.
Here's what I priced out awhile back to convert Julian's already friendly 4 Stroke chassis (Arrow AX-9 4S, he's been driving a four stroke chassis the whole time in JA, best chassis for the class IMO because of that versatility):
World Formula Engine: $900 (this was a good deal I found on a new one)
WF engine install accessories: $450
engine mount
clutch guard
sprocket guard
219 chain
219 split sprocket (I own a ton of Sprockets, but none are split)
Battery
battery bracket/mount
2-30mm frame clamps
wiring harness
WF exhaust silencer
silencer bumper clamp
So, count on $1350+ if you want battery start (I assume that's the whole point of this).
Keep in mind, the above does not include costs if the WF doesn't fit your chassis just right, and if you currently own a standard 2 Stroke Chassis, *most* will require slight modifications or other ways for the motor to adapt.
You could get very lucky and find a great deal on a package that's already together, but because the WF is not a popular race class everywhere in the country, it's tough to find one near you. If it's not near you, you'll want to factor in shipping costs ($300-ish).
I would love to switch over, particularly on Julian's kart, but it makes no financial sense for us at this point.
Karl Hughes
PostPosted: Mon May 07, 2012 9:30 am    Post subject: Reply with quote
I went through the same evaluation Brian did, and came up with very similar numbers. My son's kart is an antique Trick with a Raptor, and upgrading was looking like it wasn't worth doing with that kart.
I ended buying a complete WF-equipped kart from a friend whose son turned 16 and became eligible to drive actual cars. I was lucky to have this come up when I needed it at about the price of the conversion.
Now all I have to do is get the comparatively tiny seat mounted (my eleven-year-old is a bit smaller than the previous driver), add lots of lead, and install the JB restrictor kit. This one is pull start, not electric, but it is a lot easier to start than the Raptor, and the pull starter is attached. Eventually we'll add electric start, since there will be plenty of lead we can take off.
Joe Ricard
PostPosted: Mon May 07, 2012 11:57 am    Post subject: Reply with quote
It's been awhile since I read the FJ rules but I seem to remember something silly about the WF had to have the starter attached. but the battery was optional.
If you need one I have an extra.
Alan Sheidler
PostPosted: Mon May 07, 2012 7:28 pm    Post subject: Reply with quote
Yes, the WF motor must be run as manufactured, with the starter in place. It should be complete (not gutted) and theoretically capable of starting the motor if hooked up to a battery and switch system. The one we have on our WF has never been energized. That WF motor is so easy to start with the recoil, that I never set up the on-board battery, even though I had an appropriate cell, and the proper style momentary switch.
Tom Reynolds
PostPosted: Tue May 08, 2012 9:02 am    Post subject: Reply with quote
FWIW, it has been discussed to make the starter now optional with a cover plate to give access to the slightly heavier drivers. I could easily see this happen at some point in the near future as I believe others like the WKA allow this.
Karl Hughes
PostPosted: Wed May 09, 2012 7:07 pm    Post subject: Reply with quote
This kart was a road racer in its previous life, where I assume the starter was optional. Joe, I'm definitely interested in the starter.
-Karl
Page 6 of 6
DB time: 0.10703 (49.66%), total time:0.215518, queries:38
