OTK - LB
Ribtect - SS (non-flash)
Brief update on FJ spec motor proposal
Joe Ricard
PostPosted: Mon Jan 23, 2012 10:51 am    Post subject: Reply with quote
I don't think any of the FJ trophy winners were Autocross only.
I never realized the huge improvement a kid will get with a few lapping days at a sprint track. Since getting my youngin out to the sprint track he got considerably faster in the cone dodging gig.
Now have a WF with new slide restrictor, Stock Raptor on Gas, and new to the stable is a Mini Max. Can you guess which one he likes the best????
Arrow AX-8/ Rotax Sr.
Brian Garfield
PostPosted: Mon Jan 23, 2012 11:54 am    Post subject: Reply with quote
Seeing as how the Mini Max is a JA-motor (however, correct for his age in Sprint racing), I'll go with that, at least 4-5hp more...
Joe Ricard
PostPosted: Mon Jan 23, 2012 12:19 pm    Post subject: Reply with quote
Yup, and 265 lbs is only 55lbs of lead away and good for 2 more years.
JA + mini max =305lbs
This is his last year in JB Raptor 245 lbs. or WF restricted @ 255 lbs.
decisions decisions.........
Shawn P. Hill
PostPosted: Mon Jan 23, 2012 12:53 pm    Post subject: Reply with quote
I don't fully understand the want or need to move to a spec motor. I'm doing a bunch of research on it and trying to be as open minded about it as possible but just cant seem to justify having 1 motor option that isn't prevalent in other forms of kart racing that could be done with the same chassis.
My oldest is 5 and he can't wait for the weather to warm up so he can go to the track in his new toy. I have plans for us to both sprint race if he's up for it and both autocross is he's up for it. I don't want to have 2 karts in the stable that depend on where we are racing as to which one to use.
I do like the idea of an "easy" solution for the non karting dads that want little Jimmy to come play as well. That. sounds. great! But why exclude the others that also want to play on the sprint track too? I'd like to see us bring the top 3 or so motors together and come up with a fair way (preferably not so much weight but with throttle restrictors) to make them all competitive? I'm all for developing the WF to be as competitive as the KT100 or MiniMax. But the more I think about it and fester on it, I don't like the idea of only 1 motor option.
08 Mike Wilson Chassis - Mod Honda
Brian Garfield
PostPosted: Mon Jan 23, 2012 1:03 pm    Post subject: Reply with quote
Just to be clear, in JA, the BWF is competitive with both the KT100 and Mini Max...
The slide restrictor in JB will make the BWF competitive (or more)...
Joe Ricard
PostPosted: Mon Jan 23, 2012 1:21 pm    Post subject: Reply with quote
Fortunately for you Shawn, 5 yr olds do have a spec motor that is pretty much standard everywhere. Comer 50cc on a kid kart.
Well except my local track which has chosen the LO206 in kid RPM lmited and throttle slide. Junior 1 throttle slide, stock rev limit 225 lbs , junior 2 wide open throttle and stock rev limit @ 300 lbs.
all of which are significantly less power than the JA WF. and maybe close to a JB WF.
This is worse than picking the right house to buy based on school district. to include should we go to privte school. Rolling Eyes same thing.
Ryan Miles
PostPosted: Mon Jan 23, 2012 9:34 pm    Post subject: Reply with quote
Yes, all of that +1 ^^^
it just doesn't make any sense to me. And I also can't wrap my head around the idea that spec FJ packages will suddenly be widely available for purchase, especially if it is not a common sprint kart package. To me, that means that SCCA kart packages will be rare, and will only have resale value within the club, and will likely be expensive to put together from scratch. It seems like writing rules to protect people from themselves.
On the flip side, I do believe that it would be a huge value to our program if there was only one kart to have, and it was readily available and cheap.. Think spec miata. I just don't see how we get there from here without huge problems in the interim. It almost feels like we are over estimating our own value or pull in the market place.
To put it a third way. As F250F's start running at a regional level, I have no doubt that the stock fuel injected engines will be more consistent and easier to operate... But I wouldn't want the kart committee to ban the 125 engines because they are loud, smoky, and the newbies can't figure out how to make them run right. That's part of the learning experience.
My opinion; give these spec packages a place to play, be it a regional class, or whatever. If people gravitate towards them, new drivers will be drawn to the pool of competition, and the old classes will die a natural death. Don't write off people's karts and limit parts supply arbitrarily.
Ryan Miles
2005 Haase Future
Richard Jung
PostPosted: Wed Jan 25, 2012 9:54 am    Post subject: Reply with quote
Hi Joe,
Between your WF and the Raptor, which do you think is faster? Is your Stock Raptor blueprinted (~10hp)? Out here on the west coast, we'll probably have a rough idea of how the slide WF compares to a JB KT100, but there are no WKA built Raptors in our region.
Rick
Joe Ricard
PostPosted: Wed Jan 25, 2012 11:41 am    Post subject: Reply with quote
Between crappy weather and such I have not been able to test them head to head. Still trying to get it done this weekend.
Yes it's stock, not blueprinted, probably 8 ish to 9 HP I think. I have both karts rigged up for adults running the JB motor configuration. we can swap drivers back and forth to get a good feel for the "better" package.
You know I don't see much of a difference between the gas and Methanol powered Raptors at this level of prep. so obviously these are fairly stock. Now the one I blew up a few months back was a big deal as it had tons of compression a JE piston and longer rod. and a staggered flywheel timing key. Things you can't really see till you actually pull it apart.
Yea here we go what does a stock Raptor really look like. Rolling Eyes
Richard Jung
PostPosted: Wed Jan 25, 2012 12:10 pm    Post subject: Reply with quote
Cool. Yea, some people (myself included) didn't realize that a Raptor"5hp" was just name of the motor, not the actual hp in "stock". Smile
Rick
Joe Ricard
PostPosted: Wed Jan 25, 2012 1:22 pm    Post subject: Reply with quote
For comparison purposes our local sprint track runs the LO206 package in restricted and unrestricted forms. The Flat head raptor of my son's can flat walk away from them. So what ever the LO206 motor is spec'ed at we make more.
Joe Ricard
PostPosted: Sun Jan 29, 2012 6:07 am    Post subject: Reply with quote
Well I attempted to race the Raptor heads up against the Throttle slide restricted WF. You would think this would be easy. But keeping two karts running without bringing any of my spares is doomed before we began
Any Luckily the Raptor was the one giving me fits with fouled spark plug.
The WF fired right up and after a quick warm up we were off. I ran the same course as the cars had run all day they scored a 22.9 run after a couple runs I posted FTD of 21.3
I got nowhere near the rev limiter and it seemed to take forever to get enough RPM high enough for the clutch to lock up. (100+ feet)
Once up to speed I never lifted till reaching the finish. (scared to as it would take forever to get back to speed). So this was JB power on a full size 30MM Corsa chassis with me in it @ 160 pounds so a little over the 255 min. I put another new adult karter in the kart and he was 145 pounds and only managed a 21.9
So which one is faster is still up in the air but I have my suspicions as I am pretty familiar with Raptor power.
Richard Jung
PostPosted: Mon Jan 30, 2012 2:46 am    Post subject: Reply with quote
Thanks for sharing the data Joe. I'm probably wrong, but I thought you'd be around the 315 lb range with a WF? From second-hand prelim results I've heard today, the slide JB WF may be way fast, like 3-4sec faster than a good KT100. Sounds like time for a new engine. What's the status of the slide availability?
Rick
Robbie Nelson
PostPosted: Mon Jan 30, 2012 5:11 am    Post subject: Reply with quote
Sounds like my kids will be skipping nationals this year. Sad
Joe Ricard
PostPosted: Mon Jan 30, 2012 6:14 am    Post subject: Reply with quote
I do not think the JB WF is faster as it does not seem to have any top end. Not speficially familiar with JB KT-100 as I have only seen one running against a Raptor and we know how that came out.
Got home put a new plug in the Raptor and problem solved. But don't want to drag race them in my nieghorhood.
Page 5 of 6
DB time: 0.100192 (42.05%), total time:0.238283, queries:38
