Margay Racing
MRP - SS
DRT Racing - FB
rebuild or replace starter?
Richard Thoms
PostPosted: Mon Oct 17, 2011 3:51 pm    Post subject: rebuild or replace starter? Reply with quote
Starter went kaput. I'm considering rebuild kit (~$35) or aftermarket starter (~$100). Probably won't go for the RMax starter (~$220) - I just run club racing and usually TaG.
What is involved in a rebuild? Is it worth the trouble/savings?
Where are YOU Racing?
www.RacingWhere.com
The ultimate karting series/track/event directory!
Joey Guyon
PostPosted: Mon Oct 17, 2011 10:39 pm    Post subject: Reply with quote
Take the starter off. If the Gold housing isn't cracked and the bushing in the end isn't worn, then do a repair kit. If the housing is cracked, you can weld and grind it, but then it becomes a spare.
Ihor Bilyy
PostPosted: Tue Oct 18, 2011 3:23 pm    Post subject: Reply with quote
I tried rebuild. Its a pain in an axe. Decided to replace starter
TonyKart EVRR - Rotax Jr
http://georgiasprintkarting.net/
http://kartsetup.com/book/
Ted Murphy
PostPosted: Wed Oct 19, 2011 5:33 pm    Post subject: Reply with quote
I had to replace my starter as it crapped out during an FWT event last year. When we got back from the FWT I did rebuild the old starter to keep as a spare. As Igor noted, it is a bit of a pain to line up the brushes and get the thing bolted back together - but it's doable. Took 15 minutes or so, once the starter was off the engine.
Tim Doll
PostPosted: Thu Oct 20, 2011 7:23 pm    Post subject: Reply with quote
+1 - it's a pain to get it back together, but given the $100+ bill for a new starter it's worth the rebuilt hassle.
If you go the rebuild route, put a bit of RTV on the brush wires first - they'll last longer.
Gent (Shark Shifter) sells a trick starter support that all but eliminates the risk of breaking the gold housing. Also worth it (especially if you spring for a new starter motor).
Tim
Standard disclaimer - I'm FREE - No longer affiliated with any organization, I can say whatever I darn well please!.
Everett, Washington
PostPosted: Sun Oct 23, 2011 10:22 am    Post subject: Reply with quote
Are Rotax starters that much harder to put new brushes in than a Leopard?
ap kart racing
L.A.D Specialties
Richard Thoms
PostPosted: Fri Nov 04, 2011 3:35 pm    Post subject: Reply with quote
Got the rebuild done. It was tricky but with a little help and strategically placed index cards I was able to get the brushes installed. I did not see Tim's note about RTV until just now (doh!) but I don't think I'll open it back up for that! Next time for sure.
www.RacingWhere.com
Josh Buttafoco
PostPosted: Fri Nov 04, 2011 3:42 pm    Post subject: Reply with quote
Rotax... leopard rebuilt are both simple and easy...
Don't waste the money buying a new starter when you break a brush. Do it once and you ll kick yourself for buying that new starter.
David Flori
PostPosted: Sun Oct 28, 2012 5:29 pm    Post subject: Reply with quote
Where are good places to get the replacement brushes?
Any quality and inexpensive options?
Can we just walk in to a place that carries brushes and get the size that fits these rotax starters, or are there any strange features or compounds that make it worth getting the standard replacement kits?
Seems like a fairly standard brush, with a side/top cast brush wire being the only specialty about it.
If replacement is required,is it better to go with the OEM rotax starter or OK to go aftermarket for the starter in this specific case?
Where are the best places to go to get a replacement starter both aftermarket and OEM?
TIA
Chris Rock
PostPosted: Mon Oct 29, 2012 6:34 am    Post subject: brush replacement Reply with quote
From the Leopard owners manual
Start at page 36
brush replacement
It's actually pretty easy to do once you make the two little U shaped wire pieces
David Flori
PostPosted: Tue Nov 20, 2012 10:27 pm    Post subject: Reply with quote
Looked around, any good reasonably priced sources to replace the brushes someone could pass along?
I have looked at my starter, and it really only needs to have the brushes replaced, and it will be good as new if i can find a reasonable source.
If I can find some reasonably priced units I will surely hit them with a little RTV or silicone or rubberization product to damp them and inhibit vibration.
TIA
DB time: 0.119455 (37.51%), total time:0.318446, queries:38
