SKUSA (non-flash) - LB
Karting Tools for Android mobile phones
Goto page Previous  1, 2, 3, 4, 5  Next
Fabien Michon
PostPosted: Fri Mar 02, 2012 11:56 am    Post subject: Reply with quote
Thank you for your help !
Fabien Michon
PostPosted: Tue Mar 13, 2012 2:54 pm    Post subject: Reply with quote
Hello,
Karting Tools came in 1.11 version with the following features :
- new gear ratio calculator feature
- add 6 french tracks : Saint-Benoît-sur-Loire, Rochy-Condé, Juvaincourt, Val d'Argenton, Abbeville and Valence
- fuel/oil mix ratio : add more precision for oil value
- track country preference with country detection
- fix a flag description
I'm working on the multi racers stopwatch !
Steve Moody
PostPosted: Tue Mar 13, 2012 3:07 pm    Post subject: Reply with quote
I just downloaded the app. It looks pretty good. Took me a little while to figure out the gear calc, but I like that you can lock one of the parameters and adjust the others to get where you want.
I have a suggestion for the lap timer though. When you press stop it gives you your total and the last lap up on the top row, but doesn't show you the last lap down in the lap listing, and therefore doesn't take into effect the fastest lap if it happens on the last lap.
Otherwise, cool app, I look forward to updates.
Fabien Michon
PostPosted: Wed Mar 14, 2012 2:08 pm    Post subject: Reply with quote
Hello Steve,
Thank you !
I think user will press "lap button" on the finishing line and press "stop button" after. If a new lap is recorded by pressing "stop button", the best lap will be a false lap. Are you ok with this ?
patrick slattery
PostPosted: Fri Mar 16, 2012 7:00 am    Post subject: Reply with quote
Fabien, your doing a good job trying to tweak the program, keep it up!!
Add some USA Tracks Smile
Fabien Michon
PostPosted: Fri Mar 16, 2012 7:19 am    Post subject: Reply with quote
Thank you so much Patrick !
USA tracks will be added if french users will like the french tracks feature in Pro version. Adding all word tracks is a huge work !
Fabien Michon
PostPosted: Sun Apr 22, 2012 1:30 pm    Post subject: Reply with quote
Hello,
Karting Tools came in 1.12 version with the following features :
- multiple stopwatch (beta version)
- + or - volume button instead of the start/lap button
- more than 60 french/belgium tracks phone
- inch/cm preference
Feel free to give your feedback !
Fabien Michon
PostPosted: Mon Jun 18, 2012 1:18 pm    Post subject: Reply with quote
Hello,
Karting Tools came in 2.0 version with the following features :
- new user interface
- several Netherlands and Germany tracks : Kartpark Emsbüren, Kartbahn Hunsrückring Hahn, Kartcircuit Pottendijk, Circuit de Landsard, Circuit Park Berghem, Kartbaan Vledderveen, Kartbaan Strijen, Karting Eefde, Kartbaan Driebergen (4-stroke), Kartbaan Oldenzaal (4-stroke), Kartcircuit Alnone (4-stroke), Kartbaan Ulrum (4-stroke)
- sd card installation enabled
- a new french track : Mer
- end-user license agreement
- remove the “reset all” features after “stop all” in order to see the lap times
Thanks a lot to Dennis for his huge work on the Netherlands and Germany tracks ! Feel free to contact us to suggest gear ratios or tracks.
Fabien Michon
PostPosted: Tue Jul 17, 2012 2:07 pm    Post subject: Reply with quote
Hello,
Karting Tools came in 2.1 version with the following features :
- in-app billing of 2 pro features, one year after the release of the free version
- add Malaysia’s tracks : many thanks to Dennis from TNR Motorsport (OMP Distributor) !
- add a new french tracks : La Planche, Ploumoguer, Lamballe, and Plumeliau
- several tracks updates
Thank you for your feedbacks.
Fabien Michon
PostPosted: Sun Sep 02, 2012 2:29 am    Post subject: Reply with quote
Hello,
Karting Tools came in 2.2 version with the following features :
- add the first United Kingdom tracks with automatic country detection
- tracks displayed in a world map
This is a video :
http://www.youtube.com/watch?v=BqZbqOuYpRU
Fabien Michon
PostPosted: Sun Oct 07, 2012 3:18 am    Post subject: Reply with quote
Hello,
There is a new Karting Tools version (2.3) with the following features :
- new United Kingdom tracks : Bayford Meadows, Golspie, Blackbushe, Crail, Kimbolton, Warden Law, Nutts Corner, Dunkeswell, Buckmore, Boyndie
- new French tracks : Château-Gaillard, Loudun
- UK cadet gearing management
Jeff Stamper
PostPosted: Sun Oct 07, 2012 6:40 am    Post subject: Reply with quote
I just downloaded the app and the gear ratio does not seem to work. I cannot change the drive gear for some reason. Am I doing anything wrong ?
Racing is a State of Mind ! ... A very nice state to be in !
Fabien Michon
PostPosted: Sun Oct 07, 2012 11:05 am    Post subject: Reply with quote
Hello Jeff,
This features contains 3 lock buttons :
A) front sprocket teeth
B) rear sprocket teeth
C) gear ratio
One of them is locked so you can only update other lines (C depends on B&C, A depends on B&C, B depends on A&C).
Do you see which line is locked on your phone ?
Jeff Stamper
PostPosted: Sun Oct 07, 2012 6:24 pm    Post subject: Reply with quote
I figured it out, but it doesnt go high enough for the 4 cycle guys ! I run up to 23 driver ! Usually run 18 in Sprints
Fabien Michon
PostPosted: Mon Oct 08, 2012 5:11 am    Post subject: Reply with quote
Ok, I'm sorry, in France we haven't front sprocket > 14 teeth.
Currently :
- front sprocket : 9 to 14
- rear sprocket : 63 to 94
In your opinion, how must I update theses limits ?
Page 2 of 5
DB time: 0.279776 (56.34%), total time:0.496616, queries:38
