Italian Motors - LB
Top Kart USA - SS
Tony Kart/Vortex - FB
Cleaning the crankshaft on a seized World Formula
Jim Simpson
PostPosted: Thu Aug 18, 2011 6:04 pm    Post subject: Cleaning the crankshaft on a seized World Formula Reply with quote
Any advice on what to use to clean the connecting rod metal off of the crankshaft of a seized World Formula motor. Any help would be appreciated.
Bernie Lacotta
PostPosted: Fri Aug 19, 2011 7:26 am    Post subject: Re: Cleaning the crankshaft on a seized World Formula Reply with quote
[quote="Jim Simpson"]Any advice on what to use to clean the connecting rod metal off of the crankshaft of a seized World Formula motor. Any help would be appreciated.[/quote
In a word ,"don't "! It's just about impossible to get the microscopic pieces of aluminum out of the the crank. The cranks should not be polished as they relie on a specific finish to retain lubrication. The time and money spent trying to repair the crank will easily exceed the cost of a new one.
I breathe ,therefore,I race
Robert Brooks
PostPosted: Fri Aug 19, 2011 9:08 pm    Post subject: Reply with quote
I think a new crank is about $89.00
Straightaways are for fast karts, corners are for fast drivers....
Bernie Lacotta
PostPosted: Sat Aug 20, 2011 6:10 am    Post subject: Reply with quote
You can get the forged crank from Faster Motors for $58.09 ( www.fastermotors.net )
Robert Brooks
PostPosted: Sat Aug 20, 2011 8:44 am    Post subject: Reply with quote
not worth messing with it for $60
Chris Hatch
PostPosted: Mon Aug 22, 2011 7:42 pm    Post subject: Reply with quote
Muratic acid. But it's not worth it for $60. Get the new crank.
mike clements
PostPosted: Thu Dec 29, 2011 1:58 pm    Post subject: Reply with quote
I have cleaned off the "stuck on" aluminum from Briggs cranks for years with no problem. Takes about 10 mins at most. Muratic acid, then some 600 grit cloth and then some 1000 grit. Put it back together and run FHS-62R oil. Works every time.
Began kart racing 1959. Made many friends along the way.
DB time: 0.365919 (75.95%), total time:0.481763, queries:38
