Jake Wilmott
Joined: 13 Jul 2011 Posts: 57 Location: United States, New York,
Posted: Tue Aug 02, 2011 3:33 pm Post subject: Fuel/Oil Mixture with MS98L? |
| Ok, so I finally got some fuel for my kart. I got MS98L. What would people recommend for a fuel/oil mix for this specific fuel? My engine is a built CR125. Also, I have Castor927 2-cycle oil...is this safe/good to use? |
Jim McMahon
Joined: 07 Apr 2007 Posts: 2772 Location: United States, St. Paul,
Posted: Tue Aug 02, 2011 7:11 pm Post subject: |
Maxima927 is a good oil. Run it around 4%: 24:1 or 6oz/gal _________________ CES Grattan pre-entry is open. TaG, Shifter, KPV, KT100, Animal\LO206, enduro or superkart.
Click Here to enter Grattan online |
Jake Wilmott
Posted: Tue Aug 02, 2011 7:35 pm Post subject: |
| Alright, I will do that. Thanks for the reply! |
Keith Bridgeman
Joined: 24 Aug 2001 Posts: 1348 Location: United States, Minnesota, Farmington
Michael Taksa
Joined: 25 Jul 2001 Posts: 1426 Location: United States, Massachusetts, Boston
Posted: Wed Aug 03, 2011 8:32 am Post subject: |
| Any GOOD karting specifix engine oil castor or syntetic at 6-8 oz / gallon is good. |
Randy Mckee
Posted: Wed Aug 03, 2011 12:31 pm Post subject: |
Jake, you mentioned it's a "built" cr125; do you know anything about the "build" of that motor? It may require higher octane than ms98. _________________ Randy
#123 TonyKart - S4 Stock Honda |
Jim McMahon
Posted: Wed Aug 03, 2011 1:05 pm Post subject: |
| Randy Mckee wrote: | | Jake, you mentioned it's a "built" cr125; do you know anything about the "build" of that motor? It may require higher octane than ms98. |
Good catch Randy, I missed that. If it's modded then you are looking at PV C12. Same oil and ratio is fine. You might get away with MS98 if its modded, but you better pick the least aggressive ignition map and jet rich. _________________ CES Grattan pre-entry is open. TaG, Shifter, KPV, KT100, Animal\LO206, enduro or superkart.
Roy Montgomery
Joined: 12 Jul 2010 Posts: 166 Location: United States, Texas, Humble
Posted: Wed Aug 03, 2011 1:15 pm Post subject: |
| C-12 for sure ! |
Jake Wilmott
Posted: Wed Aug 03, 2011 1:29 pm Post subject: |
| Jim McMahon wrote: | | Randy Mckee wrote: | | Jake, you mentioned it's a "built" cr125; do you know anything about the "build" of that motor? It may require higher octane than ms98. |
Good catch Randy, I missed that. If it's modded then you are looking at PV C12. Same oil and ratio is fine. You might get away with MS98 if its modded, but you better pick the least aggressive ignition map and jet rich. |
Well that's the problem.... I don't exactly what was done. I know it has an Extreme Karting top end on it but I don't know anything other than that. How can you change the ignition map? |
Roy Montgomery
Posted: Wed Aug 03, 2011 1:31 pm Post subject: |
Jake...
Is this a GP6 with a Darcy (DDR) Built Moto? White Pods? |
Jake Wilmott
Posted: Wed Aug 03, 2011 1:36 pm Post subject: |
| Roy Montgomery wrote: | Jake...
I wish I could tell you! I have no idea haha. I am brand new to karting so I am unsure of all the specs.... |
Roy Montgomery
Posted: Wed Aug 03, 2011 1:37 pm Post subject: |
Did you recently buy the kart from Doug at Extreme Karting?
If so I know the kart/engine very well.
Does it have white bodywork and a blue frame? |
Jake Wilmott
Posted: Wed Aug 03, 2011 1:38 pm Post subject: |
| Roy Montgomery wrote: | Did you recently buy the kart from Doug at Extreme Karting?
I didn't buy it from a guy named Doug. It is a GP kart....is the GP6 referring to the type of chassis? |
Roy Montgomery
Posted: Wed Aug 03, 2011 1:40 pm Post subject: |
ok.... you mentioned it had an extreme karting top end.
Does the engine have white stickers on the cylinder and a yellow box on the back of the seat?
Is the bodywork white? |
Jake Wilmott
Posted: Wed Aug 03, 2011 1:42 pm Post subject: |
| Roy Montgomery wrote: | ok.... you mentioned it had an extreme karting top end.
It has a metal name plate on the top of the engine that says "Extreme Karting" The bodywork is almost entirely blue but there is a bit of white on it. There isn't a yellow box on the back of the seat. |
