Bondurant - LB
Brett King Design
KG Plastics - FB
help needed finding problem on cr125 transmission
Goto page Previous  1, 2, 3, 4, 5
Todd Kageals
PostPosted: Fri Nov 30, 2012 12:23 pm    Post subject: Reply with quote
Chris,
Where do I put the shim? Should I just turn one on the lathe? 2mm? I assume? I assume I am basically installing a washer that would take up the space of the wider gear??
Chris Reinhardt wrote:
Todd Kageals wrote:
OK....just making sure here. I have a '94 transmission ("narrow" I believe) but I have '99 cases (assume these are "wide"). So....all I need to do is get the '97 main shaft and move all my gears etc. from the '94 over to the new shaft. I don't need any shimming etc. Correct?
I'd just shim my '94 transmission but I don't see anyone saying that they have done this and that it works!
It works!
CR
PostPosted: Fri Nov 30, 2012 1:20 pm    Post subject: Reply with quote
Todd, I can't explain how to shim a transmission over the internet Shocked
If you like pack up and ship it to me, I would glad to help out.....
CR
East Coast Super Kart Series
"This is how we roll!"
"Home of Cobalt Superkarts"
www.CR2MotorSports.webs.com
Todd Kageals
PostPosted: Fri Nov 30, 2012 1:52 pm    Post subject: Reply with quote
Well....I really appreciate the offer and it may come to that....wish I had known that before I tried the swap. Hell....at this point I might just put the 5 speed back in it an be done!
Todd Kageals
PostPosted: Fri Nov 30, 2012 2:04 pm    Post subject: Reply with quote
Is it as simple as shimming the distance to make up for the extra width of the built in gear?
Todd Kageals
PostPosted: Fri Nov 30, 2012 3:26 pm    Post subject: 6 speed shaft longer than 5 speed shaft????? Reply with quote
Well....this does not make any sense. The 6 speed shaft is actually LONGER than the 5 speed shaft that came out of the '99. I'm speaking of the distance from edge to edge of the gear pack (the part between the bearings). I included the thrust washers when I measured. How can THAT be right?????
PostPosted: Fri Nov 30, 2012 4:33 pm    Post subject: Reply with quote
This is why I can't explain this over the internet.....
CR
Todd Kageals
PostPosted: Fri Nov 30, 2012 5:48 pm    Post subject: Reply with quote
Well can you give me a hint??? Please??? I'm begging here!!!!! Seriously....I'd rather do it myself so that I can learn for the future (generally I try to do all my own work). However, I'll send it to you if I must. What all would you need? The cases (all new bearings are already installed), six speed tranny, crankshaft and gasket?
CR
PostPosted: Fri Nov 30, 2012 5:52 pm    Post subject: Reply with quote
Todd, I'm sorry, I'm not really going to get into on here, if someone can't figure it out from all the information that's posted, then you really shouldn't doing it....
Todd Kageals
PostPosted: Sat Dec 01, 2012 5:24 am    Post subject: Reply with quote
Well.....I'll send it to you if you are willing to do it for me. What all would you need?
Page 5 of 5
DB time: 0.086113 (43.7%), total time:0.197045, queries:38
