IKF Region 7 - LB
RLV - SS
Leading Edge Motorsports
help needed finding problem on cr125 transmission
Goto page Previous  1, 2, 3, 4, 5  Next
PostPosted: Sat Jul 09, 2011 5:03 am    Post subject: Reply with quote
I would replace the shaft, this way there's no question about the location of the gears.
PM me and I'll tell you where to send the check.... Very Happy
Now you can go to the bathroom Laughing
CR
East Coast Super Kart Series
"This is how we roll!"
"Home of Cobalt Superkarts"
www.CR2MotorSports.webs.com
Mike Goebel
PostPosted: Sat Jul 09, 2011 10:16 am    Post subject: Reply with quote
Jaun,
I'm sorry to say that you will get the shaft again.
Get the right one and be done with it.
Mike G.
PostPosted: Sat Jul 09, 2011 11:23 am    Post subject: Reply with quote
Mike Goebel wrote:
Jaun,
Mike G.
Nice work there Captain Obvious.... Laughing
CR
Juan Jaramillo
PostPosted: Fri Jul 15, 2011 6:31 pm    Post subject: Reply with quote
Ok, I got the new shaft today and it's not that one shaft is longer than the other, it's the gear that it's thicker. But the gears side is identical. the diference is on the other side. I'll post pictures next week.
http://www.goherbalife.com/roanoke
Herbalife Independent Distributor
Lose weight now!
PostPosted: Sat Jul 16, 2011 6:48 am    Post subject: Reply with quote
What shaft did you order, did you measure it the same way we did the old one?
CR
Anthony Iuzzo
PostPosted: Sat Jul 16, 2011 9:31 pm    Post subject: Reply with quote
If you ordered the #23210-KZ4-A10 mainshaft it IS slightly longer and the gear is wider on the shaft.....either way if it differs from the shaft you have, you have the wrong one in your trans...
Juan Jaramillo
PostPosted: Sun Jul 17, 2011 8:19 pm    Post subject: Reply with quote
OK here are the pics,
Shaft ordered:
A10 on the left same length. About 179.5 mm each (sorry I don't have a caliper that long)
Gears are 1.5 mm diff and as you can see the bottom side of shaft is the same length (gears side).
But yes as CR points of measure being one gear thicker 1.5mm than the other it makes the part that goes inside the cases longer than the other.
Lose weight now!
Last edited by Juan Jaramillo on Mon Jul 18, 2011 7:11 am, edited 2 times in total
PostPosted: Sun Jul 17, 2011 8:49 pm    Post subject: Reply with quote
BINGO!!!! You fixed it!!!
Did you damage any gears second time around?
Do you have the service manual for the 97 motor? The washers and snap rings need to oriented the correct way.
CR
Juan Jaramillo
PostPosted: Sun Jul 17, 2011 9:00 pm    Post subject: Reply with quote
Not yet, I will try to put it back together this week, I have an 89-91 manual and some graphs from kartweb showing washers orientation.
Lose weight now!
PostPosted: Sun Jul 17, 2011 9:02 pm    Post subject: Reply with quote
Cool, you're on the right track now....
CR
Steve Buckner
PostPosted: Sun Jul 17, 2011 10:12 pm    Post subject: Reply with quote
Good job Chris, This is what Forums should be like. Helping a bro out. Cool
Leave the soap opera crap for the weak.
Anthony Iuzzo
PostPosted: Mon Jul 18, 2011 3:03 pm    Post subject: Reply with quote
glad you have it figured out......maybe it's the picture angle but the shaft on the left does look ever so slightly longer Laughing but either way now you have the correct shaft...
Juan Jaramillo
PostPosted: Mon Jul 18, 2011 7:57 pm    Post subject: Reply with quote
OK Guys, I measured each case from top of bearing to bottom of ruler. Left side 57.47mm
Right side from top of bearing to bottom of ruler 42.19mm
Total= 99.66mm
23210-KZA-A10 mainshaft = 99.82
RIGHT ON TARGET!
Lose weight now!
Todd Kageals
PostPosted: Fri Nov 30, 2012 10:27 am    Post subject: Reply with quote
OK....just making sure here. I have a '94 transmission ("narrow" I believe) but I have '99 cases (assume these are "wide"). So....all I need to do is get the '97 main shaft and move all my gears etc. from the '94 over to the new shaft. I don't need any shimming etc. Correct?
I'd just shim my '94 transmission but I don't see anyone saying that they have done this and that it works!
PostPosted: Fri Nov 30, 2012 11:09 am    Post subject: Reply with quote
It works!
CR
Page 4 of 5
DB time: 0.116689 (35.02%), total time:0.333253, queries:38
