world formula ignition tech
ted tucholski
PostPosted: Mon Apr 25, 2011 9:36 pm    Post subject: world formula ignition tech Reply with quote
What are the rules for ignition tech on a world formula in the 2011 IKF manual. Is the ignition adjustable by several degrees.
Bernie Lacotta
PostPosted: Tue Apr 26, 2011 7:11 am    Post subject: Re: world formula ignition tech Reply with quote
Ted , go to www.4cycle.com , Karting forums , Ohv engines , World Formula , and search for "IKF Tec Rules Conflict ", the info there may help on the ignition rule in the book.
I wish I could " cut and paste " !!!
I breathe ,therefore,I race
Chris Hatch
PostPosted: Sat May 14, 2011 3:21 pm    Post subject: Reply with quote
You are required to use the stock key and the the timing is taken when magnets leading edge touches the foremost magneto arm. IKF tech says it should read at 24-27 degrees timing (about 27-29 BTDC actual timing).
Wayne ONeil
PostPosted: Mon May 16, 2011 8:31 am    Post subject: Reply with quote
Isn't there a minimum width specified for the flywheel key? I've heard of engine builders shaving flywheel keys to meet this minimum so that the timing could be advanced as far as possible.
http://teamwishbone.com
http://myspace.com/teamwishbone
Chris Hatch
PostPosted: Wed May 18, 2011 10:10 pm    Post subject: Reply with quote
There is a minimum key width. .182 I think.
DB time: 0.067966999999999 (42.38%), total time:0.160393, queries:38
