Home Forums Classifieds Classifieds – Misc. Yard Sale!!!
This topic contains 0 replies, has 1 voice, and was last updated by  Eric Petrie 2 years, 6 months ago.
Viewing 1 post (of 1 total)
  • #32308
    Eric Petrie
    YARD SALE EVERYTHING MUST GO!!!!
    <div class=”bbp-reply-content”>
    <div id=”d4p-bbp-quote-32303″>
    I am no longer running the Rotax Max Sr series any longer so all equipment and gear is available. Everything is priced but will take reasonable offers for anything. I am not interested in any trades. Located in Denver, CO but can travel within reasonable distances. If interested please email at ecpetrie1989@yahoo.com or call 720-272-6151.
    Alpine stars KMX-9 size 50 (med) race suit used- $50
    Shockwave karting 95mm pro metric rear racing hub set $50
    Tire Bead Breaker $30
    NEW Mojo Rain tires, current compound, mounted magnesium wheels $225
    Additional Low Volume and Regular Magnesium Douglas Wheels $60
    Lightly used Mojo D2 and Bridgestone tires $50 set
    2012 Sodi Sigma $1500
    Wheelbase : 1040 mm
    • Frame : Double tube removable, CIK approved
    • Removable front stabilizer, adjustable front chassis geometry using eccentrics
    • Tube : Chrome molybdenum steel, ø 32
    • Rear axle : Hollow steel, ø 50 – 3 bearings, ø 80
    • Axle bearing supports : Anodized, quick release, ø 80
    • Stub axles : ø 25 mm
    • Rear hubs : Long with twin pinch bolts, anodized, fully machined, L. 90 mm
    • Brake : 4 piston hydraulic brake system. CIK approved under number 37/FR/14
    • Brake disk : Rear : floating, turbo ventilated CI, ø 205 mm, thickness 18 mm with increased ventilation. Front : floating 2 disks, turbo ventilated CI, ø 140 mm with increased ventilation
    • Front wheels : Magnesium, 130 mm, 2 sets
    • Rear wheels : Magnesium, 212 mm, 2 sets
    • Tank : Removable 8,5 L
    • Seat : Clear polyester with ¼ side pad, black,
    • Steering wheel : Aluminum with suede-type covering, Sodi logo embroiled
    • Security : Protective base plate for brake disk, brake pedal with 2 points attachment, integral chain cover, anti-locking bar
    • Frame color : Dark grey + varnish
    • Bodywork : KG Sodi CIK approved
    • Rear bumper : KG plastic
    Mychron 4, Green Screen, temp, rpm and infrared lap transponder leads
    • Assortment of single piece gears, 71-79, chains included
    • Complete Sodi sticker kit with additional kit pieces
    • Comes with multiple sets of lightly used mojo tires and Bridgestone tires, if still available new rain tires on mounted magnesium wheels
    • Comes with Street Karter foldable Kart Stand, painted to match Sodi Grey
    • Additional side bars, Teflon and aluminum with mounting brackets
    • Mounted front bar, aluminum
    • Mounted foot rest, adjustable
    •Shockwave karting 95mm pro metric rear racing hub set
    • Misc hardware and equipment Sodi specific, additional weights and seat brackets
    2013 Rotax Max Engine Kit $2500
    • Lightly used, only 4 races still time before any work/ rebuild required
    • Additional Jet Set, 150-170 includes additional pilot jet
    • Still sealed with passport, all work done by approved Rotax distributer (Unser Racing)
    • All hardware, OTK engine mount, radiator, battery/ battery mount, charger
    ***Ideally want to sell kart and engine as set for $4000, includes all equipment, tires, hardware, etc
    2014 H&H Cargo Trailer $5500
    • 14 X 7 V neck, 18 feet through centerline
    • Rear Ramp door, Single side door with bar latch and lock
    • Dual axel, rated at 3500 per axel, equipped with braking system
    • 8’ telescoping tire rack, can be extended further, aluminum
    • 2 fuel jug holder, aluminum
    • Oil and liquid caddy mounted
    • 4 X 10’ E-tracks with 8 clips
    • 10 Drawer toolbox with bench top, lined drawers and secured for transit
    • Fresh painted walls and floor for clean look, includes all door locks and hitch lock
    </div>
    </div>
