Home Forums TaG X30 Radiator, stock or no?
This topic contains 2 replies, has 3 voices, and was last updated by  Larry Stevens 2 years, 10 months ago.
  • #48232
    Taylor Young
    Are many people running the stock radiator that comes with the X30? It was very hot at the Skusa Spring Nationals and almost everyone was running a larger radiator. I’m wondering if a larger aftermarket radiator is necessary when you’re racing in 80-90 degree weather as well. Anyone have experience?
    Jack Cook
    I would say go big and use a curtain. You can always reduce air flow and control water temp. You can not do much with a small radiator except put an air scoop or stand it up more.
    Larry Stevens
    Check your club rules first before making any changes to any Tag packages! For road racing with NCK you are suppose to run the stock radiators and a curtain is not legal because they are not supplied as part of the X30 engine package. I have run my Leopard for 7 years with no overheating problem even when running in 107 degree heat.
