Home Forums Classifieds Classifieds – Want to Buy (WTB) WTB OTK bearing cassettes 40/50mm
This topic contains 2 replies, has 2 voices, and was last updated by  Mike Burrill 8 months, 2 weeks ago.
  • #79996
    Mike Burrill
    Looking for a set of 2 position cassettes.  I think they were used on OTK Chassis up to 2010.  My kart is a Krypton homologation 52/ch/08.   The Cassettes have a flat on the bottom and the tension screw runs parallel to the chassis tubes. The distance between the upper and lower mounting hole is 57 mm
    Later versions have a V on the bottom  and /or have tension screws at a 45 angle to frame rails and are 60mm between the mounting holes. Those won’t work 🙁    If you have a set please let me know.  Thanks
    Mike Burrill -
    Karting Kartel
    #81031
    Cliff Kujala
    Hello Mike,
    Did you find the cassettes you need yet?
    Cliff Kujala -
    Visit us on Facebook.
    #81152
    Mike Burrill
    Nope but I did  figure out a work around though.  Do you have some used ones?
    Mike Burrill -
    Karting Kartel
