Home Forums Classifieds Classifieds – Parts WTB – Intrepid rear caliper
This topic contains 3 replies, has 2 voices, and was last updated by  Rod Balding 4 years, 2 months ago.
  • #17502
    Rod Balding
    I am needing the VEN-03 single rear caliper and mounting bracket to replace the small dual caliper system on my Intrepid Silverstone shifter kart , needs to be in excellent condition or will consider new .
    #17692
    jack lachut
    rod, i believe i have a used caliper/ bracket that i bought for a spare but never used it.
    i could not tell you if the seals would still be good.
    i can send some pics if you want, need your email.
    $100  shipped
    thanks
    #17694
    Rod Balding
    Hi Jack,
    Thanks for the reply , yes , please send pics to   rtbalding@gmail.com
    Also , would you have the floating 6 pin disc and hub assym.  I will take the caliper and bracket if its the correct one and if you have the disc send pics of it too and the diameter .
    Rod B.
    #17811
    Rod Balding
    Found the caliper and bracket , I am also looking for the 6 pin floating disc and hub assy. for a 50mm axle (I think it 190mm in diameter) needs to be in excellent or new , LMK what you have with pics and price to   rtbalding@gmail.com
