Home Forums Classifieds Classifieds – Parts WTB: Birel RY30 fuel tank and Birel 50mm Axles
This topic contains 6 replies, has 3 voices, and was last updated by  Ric mcDade 3 years ago.
  • #50161
    Joseph Bath
    I found a leak in my fuel tank. Also, my kart has some unknown used axle and I’d like to replace it with a Birel 50mm axle. Medium or Soft preferred, but I’m open to anything.
    Thanks!
    joebath@gmail.com
  • #50162
    Bill Bartsch
    I have a fuel tank for a 2008 RY30, will this work?
    • #50165
      Joseph Bath
      I think it will.  I’ll know for sure if you email me a pic.  Thanks!!!
  • #50185
    Joseph Bath
    Here are a couple pictures of my leaky tank.  I’d like to replace it with the same (without leaks).
  • #50187
    Ric mcDade
    Had a leak in a plastic Margay, thought what the heck and bought a spray can of the leak sealer you see on TV. Found it local. Cleaned with brake clean, let it dry, sprayed it with clear leak sealer. 24 hours later, I filled it with gas, and been using it ever since.
    • #50202
      Joseph Bath
      That might work for me, but the leak is behind the moulded-in nut, so I can’t actually see the leak.
  • #50208
    Ric mcDade
    Similar situation, sprayed above an let it run down, did that turning on all four sides. Worked great
