--> World Formula/L0206, Briggs class diff? – ekartingnews
Home Forums General Karting Discussion World Formula/L0206, Briggs class diff?
This topic contains 3 replies, has 3 voices, and was last updated by  Rick Brown 3 years, 4 months ago.
  • #40990
    William Butcher
    Live 1/2 & 1/2 if Fl. & NH. They race World Formula in NH
    and L0206/Briggs here in Fl. Can I use the same kart/motor set up for both? If not, what is the main difference? I’d like to run in a 4 stroke class both in NH and FL. Any help?
  • #40998
    Jon Romenesko
    World Formula and LO206 are certainly different classes.  Both are based around the same block, but the WF makes about 5hp more than a LO206 (which is around 10).  LO206 is a hand built, sealed Briggs Animal, and the WF  has a few upgrades that make the extra power.  You could probably use the same chassis and just swap the engines out, but you’ll need 2 engines if you want to run in both classes.
    This topic will probably interest you.
    Switching Between LO206 and World Formula
  • #40999
    Rick Brown
    You absolutely can use all of the same stuff. The only thing that might be different is rear tire size. A lot of people run 6″ rears in 206. We run 7.10 in world formula in the nhka.
  • #41000
    Rick Brown
    A few of us from nhka that race world formula are also thinking of heading to Rock Island to race in the 206 class
