Home Forums Tech Talk Wierd one, can you gurus help?
This topic contains 3 replies, has 2 voices, and was last updated by  greg pasley 1 year, 6 months ago.
  • #82855
    greg pasley
    I have pieced together a shifter kart that I have ran in autocross for the last 2 years.  Recently I have experienced a problem only while in first gear. When leaving the start line  and slipping the clutch, the motor will pull to about 8000 rpm then nose over and not pull further. Shifting on to higher gears and the motor pulls strong with no problems. Anyone know why this occurs only in first gear?  Thanks in advance.
  • #82893
    greg pasley
    Never mind, found it.
  • #83565
    Matt Martin
    what did the problem end up being?  that way if others have that issue, they can see what the solution might be.
  • #83568
    greg pasley
    Fuel line (feed) was cracked at fitting inside top of tank. Fearsome first gear acceleration pulled fuel line open, losing fuel pump vacuum.
