Home Forums Shifter Karts Where to Get Throttle Cable Boot?
This topic contains 4 replies, has 5 voices, and was last updated by  Rod Balding 2 years, 10 months ago.
  • #54817
    Todd Kageals
    Guys,
    I’m chasing a lean condition on my CR125 shifter and am trying to eliminate all possibilities.  I have noticed that I am missing the rubber boot that goes on the top of the carburetor around the throttle cable.  Where can I get this part?  It did not come with carb and I just assume it’s not a Honda part since the PWK I have on there is not the original Honda carb.
    Todd
  • #54830
    Bill Schmidt
    Any place that sells keihin carb parts will have that part for sale.
  • #55304
    James O’Brien
    These are nice too Todd
    www.eshifterkart.com
  • #55316
    Brad Alan
    If you’re back at the track before you get the appropriate boot, just wrap it with electrical tape.  It will work for the day and will let you know if that’s the problem quickly…
  • #55326
    Rod Balding
    The boot might help , but I doubt it , you will still be sucking a certain amount of air through the cable housing , you can use a piece of fuel line and a zip tie to hold the cable housing to the carb top
