Home Forums Autocross / Solo 2 Whats a Vortex engine worth?
This topic contains 2 replies, has 3 voices, and was last updated by  Joe Ricard 3 years, 11 months ago.
  • #20516
    Bill Schmidt
    Jason Vehige
    Without the pipe and carb less than the starting bid ūüôā ¬† If it was a complete setup and 100% fresh 2k is an ok price… No proof on the bottom end rebuild would drop my max to 1500..
    #20549
    Joe Ricard
    Bill you would do well with an ICC.¬† However you need to jump in Jason’s back pocket for the tricks to make SOLO with ICC livable.
    I had an ICC¬† Vortex RVS and it is a monster that was built by DDC.¬†¬† When taken to the limit of the SCCA and Homolugation rules it is going to be significant money.¬†¬† And as Jason said¬† Get a whole package¬† Air box to pipe and mount, drive gears.¬† carb jets, needles, atomizers. motor mount. and don’t forget water pump and radiator.¬† I paid 2500 for a turn key¬†RVS which was hot in the day but these are 2004 vintage.¬† and then had to put a top end in it.
