Home Forums Shifter Karts ?What V-Force Reeds do I use?
This topic contains 2 replies, has 3 voices, and was last updated by  Jason 4 years, 7 months ago.
  • #4899
    Jason Lorang
    I am new to the Stock Honda class… I have a 01 cr125 and I am unsure which V-Force reed system I should use? 3? 4?? Help!!
    #4920
    Tyson Henry
    If you are trying to race in stock Honda, you should use a stock Honda 99′ reed cage. The reeds are open, just not multi-stage I believe?
    You might want to research stock Honda rules a bit more than you have.
    Where are you planning on racing?
    #4940
    Jason
    Purchase a rulebook from the proper association that governs your racing series.  The SKUSA rulebook can be downloaded from their site.  http://www.superkartsusa.com/rulebook.html
    Per SKUSA rules, Stock moto must use a 1999 intake boot (marked with a KZ4-M), a 1999 reed cage (3 windows per side), and reeds are sort of “open”.  The use of a Boyesen style dual stage reed is not permitted.
    Before you grab a tool, read the rulebook.
