Home Forums Shifter Karts What silencer to use on my CR85 Shifter for Anderson Race Park in Palmetto, FL?
This topic contains 11 replies, has 4 voices, and was last updated by  Derek Lodato 4 years, 6 months ago.
  • #23605
    Derek Lodato
    I am in search of the precise silencer to use for Anderson Race Park. I am looking at either an 8″ or 12″ Alden A3 Silencer. I have attached the layout of the track I will mainly be running sessions on .. please let me know which silencer would work best. AND as a bonus let me know  which pipe would work best on this track an RLV TC4 or RLV TC8?
  • #23607
    Stephen Lamana
    How long is the straight away? Tight infield section?
  • #23634
    Derek Lodato
    There is a front straight by the pits that is about 600ft … if you look at the map when they open up the full course the back straight goes about 700ft+ then sweeps to the right but it is almost an all out sweeper with light blips off the throttle. That whole section is good amount of feet.
    If they close the full course the track becomes more tight with about a 600ft + straight.
  • #23638
    Dennis Chappell
    Have you called Danny at Alden and ask him what he thinks. They dyno the silencers and should be able to help you out.
    Dennis Chappell
  • #23645
    Stephen Lamana
    You want a short silencer for short straights. So I would Start with a TC4/8in silencer
  • #23718
    Go with the longest silencer you can fit. They have very strict noise restrictions down there an 8″ may get you black flaged. They very rarely go to full track. With the normal track configuration I don’t thing a longer silencer will be a problem.
  • #23730
    Derek Lodato
    Thanks guys .. @ Brian ..I didn’t think about the noise restrictions .. with that said I’ll most likely go with the 12″ Alden A3.
    What about pipe – Stephen you mentioned going with the TC4 .. is this the better choice over a TC8? I am not well versed on these pipes.. what is the difference?
    Thanks again,
  • #23800
    Yes be carefull Derek here is the link to requirements http://www.andersenracepark.com/Testing.aspx Years ago they required all shifters including moto to have an ICC silencer. They’ve relaxed that but if your to loud they will want a longer silencer and air box. When they get a complaint they start enforcing it a little more so it’s best to try to get as quite as possible right at the start. I’m in garage 8 over there stop by and say hi.
  • #23816
    Derek Lodato
    Thanks Brian! I still have a few more things to get before my first lap. I’ll definitely stop by next time I’m out there.
  • #23832
    Derek Lodato
    Brian,
    What counter shaft gear would you run and Axel (50mm) gear for Anderson on a CR85?
  • #23844
    I don’t know about the 85CC  A 125 honda would be around 16/25
  • #23908
    Derek Lodato
    Thanks Brian … See you at the track
