--> what Oil are you using and why? – ekartingnews
Home Forums Briggs & Stratton 4-Cycle Racing what Oil are you using and why?
This topic contains 10 replies, has 8 voices, and was last updated by  Marty Troup 10 months, 1 week ago.
  • #29546
    Marty Troup
    I know there are a few oils out there amsoil- redline- ect
    but what do you run and why and do you put a additive along with it?
    also do you change it after each weekend or each race.
  • #29637
    Jon Romenesko
    I use the Amsoil 4T in my LO206.  Why?  Because it’s the Briggs recommended oil, and was developed specifically for the Animal series.  No additives, why would you need to?
    I’ve been changing it every other race weekend…still in one piece so far!
  • #29641
    Marty Troup
    Thanks Much Jon.
  • #46756
    David Klaus
    Marty,
    Briggs 4T custom blended by Amsoil is what we recommend.  This was a joint development project to give racers an oil without the severe downside of today’s karting ‘oils’ or the regular issues we see when automotive oils are used.
    Most karting oils are simply compressor lubricant and food coloring.  They found their way into karting decades ago because they have an initially high film strength, burn clean in the combustion chamber (helping pass the old school you can’t scrape carbon rule to measure piston pop-up), and are cheap allowing for a robust margin.  I would even argue that they promote consumption due to their severe limitations (both the change interval just to keep your engine together and in part sales).
    PAGs (karting oils) are hydroscopic in nature, pulling in moisture right out of the air.  This is the number 1 reason for the failures we see.  Typical tested oil samples have 1-3% water contamination.  An open bottle in your trailer, a crankcase open to air, the simple cooling of the engine after practice or sun hitting your trailer causes moisture to be absorbed.  PAGS have low solubility so additives to help prevent this cannot be added.  This is also why racers need to be especially careful when switching from PAG oils.  Crankcases need to be flushed to prevent PAG oils from separating (low solubility) and starving bearing surfaces.  Think oil and vinegar.
    With moisture comes rust and the development of an acid (resulting from the by-product of combustion and water combining).  The great initial film strength PAG oils have rapidly unravels when reaching our operating temperature AND turns to vapor out your breather.  Gone is your protection.
    PAG base oils are NOT used in ANY other form of racing or combustion engines because they simply do damage.  While I hear people tell us they have great ‘luck’ running such and such, ‘luck’ is all it is.
    Now, onto automotive oils.  If it is good enough for your car or race car, it should be just as effective in your kart engine, right?  Without naming brands some of the biggest names out there will induce failures in our engines.  While grouping oil in this category together is a generalization most are very similar in their base and additives (or lack of).  Car engines operate at lower operating temperatures (water verses air cooled).  Therefore they are engineered for this environment and above that film strength stability is compromised.  The other critical difference is this oil category is they are engineered for a pressure, not a splash lube system.  Having the benefit of pressure lube allows manufacturers to save money by not having to add unnecessary additives like ones that help prevent foaming.  So when you take a automotive oil and use it in a splash lube system it tends to foam.  Air bubbles across a bearing surface is an area without proper protection.  Even some of the most expensive automobile oils induce repeatable failures because of these shortfalls.
    Briggs 4T is our effort working with Amsoil, the leading synthetic manufacturer in the industry, to provide an oil that matches the performance (power) of it’s peers but goes beyond with an additives package that maintains film strength over time and/or in the event of fuel contamination, and rust and wear inhibitors.
    Simply put, Briggs 4T oil matches the effort and engineering we put into each engine.  It’s an oil we confidently know will give racers the best experience and life from their engine.
  • #46763
    Rob Kozakowski
    In Canada, we can’t get the Briggs 4T – or we couldn’t, labelling issue I believe – otherwise I would use it.  I use Redline 4-Stroke Kart – Briggs Racing seems to direct Canadians towards it – and because it’s readily available – I prefer to get it from kart shops, but if I need it “now”, I can pick it up at other local performance automotive shops.  We run events over Saturday and Sunday, 4 sessions per day.  I change it at the end of every Sunday.
  • #46768
    Paul Hir
    It would be nice if the cheap stuff that is available in stores locally was the recommended oil. With my Clone I used Brad Penn Oil, because it was made locally, readily available I didn’t have spend $5 in shipping to get one quart.
  • #46788
    Marty Troup
    Thanks much but I found my local amsoil dealer has the same oil as the 4T but as stated he can not carry the 4t. I can not get to my trailer at the moment to tell you the amsoil PN that is available here in Canada.
    So far he has kept it in stock I will post it asap.
  • #47917
    I use Mobil 1 0w20 16oz mixed with 4oz of Marvel Mystery oil in my clone with no problems and I know a few others that do too. You can’t go wrong with 4T or redline though. If you can’t get 4T just use the Amsoil Dominator 5W20 synthetic.
  • #47979
    Bill Angel
    Years ago we used MMO mixed in our oil in flatheads until WKA started the burn test, been away from 4 strokes awhile so I don’t know if that is still in the rules or if WKA rules are used for clones.
  • #83600
    Francois Detroio
    Hi i would like to know your opinion about the oil i use.   I read that briggs dont recommand to use car oil.  I bought a brigg 206 to my son and at the kart shop they use lucas syntech 10w60.  Im from montreal canada so we dont have briggs 4t oil.  Amsoil and redline are pretty hard to find.   If i can find better oil type those i have something special to do between the switch of oil due that some oil cant be compatible?
  • #83623
    Marty Troup
    • There are a few places in Montreal for the amsoil.
    • A good on is in Terrebonne off the 640.
    • A great price if you get a case of 12.
    • You can look them up
