--> What is needed to convert KPV2 to KPV3? – ekartingnews
Home Forums General Karting Discussion What is needed to convert KPV2 to KPV3?
This topic contains 3 replies, has 2 voices, and was last updated by  TJ Koyen 4 years, 9 months ago.
  • #5765
    Rod Hawkins
    Thinking of purchasing a couple KPV2 but I need to convert them to a kpv3.
    As I understand it, the pipe is different (is it simply 3 holes vs 2 holes, and if so, could another hole just be drilled?), the header is different and the timing might be different? Is the carb and its adjustments different as well?
    TIA, I am still new to all of this.
  • #5777
    Just the pipe is different. Probably not wise to drill a hole in a spec exhaust.
    But just grab a 3 pipe and throw it on and you should be fine. You can run a bit more RPM with the 3 pipe compared to the 2.
  • #5779
    Rod Hawkins
    TJ,
    Thanks for the reply, it is extremely hard to find any info on these things by doing a google search. Just doesn’t seem to be that much info out there. So just to be clear:
    Pipe: switch from kpv2 to KPV3
    Header: keep same
    Carb: keep same and no adjustments
    Timing: keep the same
    Trying to find a used one, eBay doesn’t seem to have any and the classifieds on this forum have crawled to a snails pace since the forum change.
  • #5794
    Yup, sounds right to me. Maybe some engine builders like to build an engine a little differently for the 3 pipe, can’t remember, but you can throw the 3 pipe on there with no issues. Carb settings are the same, around 2 – 2 1/4 on the low and 1/8 to 1/4 on the high. Not sure how you have your carb setup now, but usually we’d start the low at 1 1/2 on the grid to get rolling and once we started getting up to speed we’d open to 2 or 2 1/4.
    Header is the same.
    Classified section is a bit empty at the moment. Check your local shop or with other guys at the track who run the class. I’m sure at least one of them has a collection of used 3 pipes laying around.
