Home Forums Chassis & Handling WEIRD HANDLING
This topic contains 3 replies, has 2 voices, and was last updated by  TJ Koyen 2 years, 3 months ago.
  • #55360
    ANGEL RAMIREZ
    Hello, I am having a difficult  time to find the problem, the turns to the right seem like is over steering(on entry), and the turns to the left is almost normal but I coud said is a Little of under steering.
    is a Reynard Kart with hand front brakes and a maxter tag motor on it.
    thank’s.
    #55378
    Is your chassis bent?
    #55449
    ANGEL RAMIREZ
    good question, I’ll check for that this saturday.
    thank’s
    #55460
    If your chassis is not bent, check to make sure your setup is equal side to side. Easy to forgot to do something on one side and all of a sudden get high ride height on one side and low on the other or something silly like that.
