This topic contains 3 replies, has 3 voices, and was last updated by  William Weiler 1 year, 1 month ago.
  • #82062
    William Weiler
    My builder just put a 6″ long tube hanging out of valve vent hole on my Lo206. I need a longer piece to run to the catch can. It looks like 1/2″ tubing. I went to home depot and they only had vinyl tubing. I went to Autozone and they didn’t have 1/2″ tubing. The vinyl softens at 175 F, which I think is no good for a vent tube. Where can I get tubing locally before this weekend’s race? What is the kind of tubing (material) I should get? Thanks for your help.
    TonyKart 401s LO206
    Masters Class
    Morgan Hill, CA
  • #82079
    FREDDY SANDOVAL
    Dude!
    Just put a piece of fuel line, stick it far enough inside that molded hose and install the other end inside your catch can, done deal, it won’t fall off, been running mine for this whole season with no issues at all.
    Please make sure your catch can has one or 2 bog holes for breathing, otherwise it will drive you crazy running like crap.
    Good luck with your race.
  • #82101
    My Ace hardware had some black gas line that was big enough.
  • #82102
    William Weiler
    I was able to get some cooler hose at Autozone. It is heavier than fuel line. They have a STP/Briggs display, and I also got a fuel filter.
    TonyKart 401s LO206
    Masters Class
    Morgan Hill, CA
