Home Forums Shifter Karts VEN05 Brake Disc Direction
This topic contains 3 replies, has 4 voices, and was last updated by  Matt Martin 2 years, 8 months ago.
  • #44999
    Todd Kageals
    Guys,
    I removed the brake discs from the front of my CRG based kart with VEN05 brakes.  When I reinstalled them, I am not sure I put them on facing the right way.  Should the fins point forward or lay backwards when viewed from the side?  Does it even matter?
    Todd
    #45016
    Steen Carstensen
    The fins should always point towards the back. The air moves from the center toward the outside as the rotor is spinning. Same principle as any pump.
    #45021
    Alan Sheidler
    Ventilated rotors behave essentially like radial fans.  Air pumps, like Steen says.  If the internal vanes are straight, obviously it does not matter which way they spin.  But if the vanes are angled, the ends near the center should lead the outside ends in the direction of rotation.
    Something that has always bugged me is seeing aluminum wheels on cars, which have spokes shaped like they might be able to move some air.  But they are almost always identical no matter which corner they are on.  To me that makes it look like they are backwards on one side of the car.
    #45135
    Matt Martin
