--> VEN 5 brake pad ? – ekartingnews
Home Forums General Karting Discussion VEN 5 brake pad ?
This topic contains 2 replies, has 3 voices, and was last updated by  Patrick Roth 2 years, 5 months ago.
  • #56357
    Tom Sabiel
    I need to order a set of rear brake pads for a VEN 5 with steel rotor. Do I stay with original pads or aftermarket. Thanks.
  • #56367
    Mike Clark
    I know of 1 guy that used these and liked them. Everyone else just runs stock as far as I know in the DD2 class.
    http://frixa.org/race-products
    there are 2 compounds depending on ambient temperature. They have a disc also.
  • #56401
    Patrick Roth
    I would not recommend using the Frixa brake pads on a non-Frixa rotor.  While I prefer the Frixa brake setup over the steel VEN05, my experience was when I purchased both the Frixa rotor and the pads (never tried the Frixa pads on a non-Frixa rotor).  I think I recall someone trying Frixa pads on a non-Frixa rotor and it wasn’t good at all…
    My last 4 karts were CRG’s with VEN05 brakes and I highly recommend you stick with OEM.  I have tried numerous times to save a few bucks and go with aftermarket and on several times they have disappointed me.  While some claim “OEM compound” I can’t say that they ever felt the exact same as OEM…
    If you do go with aftermarket, I have had the best luck with the ones that Acceleration Karting sells.
