Home Forums Classifieds Classifieds – Parts Various TaG kart parts
This topic contains 0 replies, has 1 voice, and was last updated by  Chris Berg 4 years, 1 month ago.
  • #27408
    Chris Berg
    Below are a list of various kart parts we have for sale. We are asking $800 $650 for the entire lot, and would like to keep from parting things out. However, if there is particular item you would like, please contact me.
    XL Tillet Seat – Sold
    Alum. Radiator – Sold
    AMB yellow transponder (w/ charger) – Sold
    Douglas Mag. rims with mounted MG rain tires – Sold
    Douglas Mag. rims with mounted MG slicks – Sold
    Dunlop kart cover – Sold
    Lots of lubricants and oils
    Exact Toe – Sold
    Rear Gears (Alum.-71, 72, 73, 75, 76, 78, 79, 80, 84, 86) (Teflon – 73, 75) – All Sold
    Kart Racewear Seat Pad – Sold
    Tire Whiz tire remover and mounter – Sold
    Airbox cover and outer filter
    Toe plates (Two sets) – Intercomp set Sold
    Tire bag – Sold
    IAME Leopard enduro clutch and drum – Sold
    IAME Leopard 10t driver – Sold
    #219 chain breaker – Sold
    IAME Leopard starter motor end
    Alum. lock collars (two) – Sold
    Engine mounts
    Alum. chassis mounting brackets (two)
    IAME clutch puller – Sold
    IAME clutch wrench – Sold
    Tollotson 334A carb – Sold
    #219 chains (Three) – Sold
    Safety Wire – Sold
    Spring puller
    Pop-off gauge – Sold
    Wheel nuts
    Intrepid eccentric pills (two sets)
    Fulcrum arm height gauge – Sold
    Tie-rod ends (five)
    Intrepid King Pin bolts (four) – Sold
    IAME Leopard reed cage
    Piston stop – Sold
    IAME thermostat
    MyChron large water temp sensor – Sold
    Various Tollotson carb. parts – Sold
    IAME Leopard clutch keys and bearings
    IAME Leopard exhaust studs (three)
    IAME Leopard ignition box rain cover
    Outerwears MyChron rain cover
    Intrepid bottom front bumper bar – Sold
    Intrepid brake parts
    Foam inner filter for airbox
    Intrepid RF spindle – Sold
    Tire bead breaker – Sold
    Tie Rods (four)
    Intrepid/SKM alum. brake bleeder
    Ratio Rite
    Extra exhaust flex
    ZoomBang seat pads – Sold
    External starter – Sold
    Please let me know, via chris.berg22@gmail.com or PM, if you have any questions.
    NorthernLights Motorsports
    chrisbergracing.weebly.com
