--> Updated List – Gears, reeds, clutch packs, engine monitors, carburetors – ekartingnews
Home Forums EKN Kart Mall Updated List – Gears, reeds, clutch packs, engine monitors, carburetors
This topic contains 1 reply, has 1 voice, and was last updated by  Jason Berry 4 years ago.
  • #24409
    Jason Berry
    TM K9C SwedeTech Blueprinted Cylinder – Replated and port clean up done by SwedeTech (ships from SwedeTech) – Has not been run since. ..$700.00
    1 Used – DellOrto PHSB 38 LD –
    1 Used – Dellorto VHSH 30 CS – No Top …$100.00
    1 Used – Dellorto VHSH 30 CS complete. …$130.00
    1 Used – Dellortor VHSB 39 ND (stamping is shallow)
    1 New – SKM 428 50mm Rear sprocket 26T …$50.00
    1 New – SKM 428 50mm Rear sprocket 28T. …$50.00
    2 USED – SKM 428 50mm Rear sprocket 23T… $25.00
    1 USED – SKM 428 50mm Rear sprocket 26T … $25.00
    2 USED – SKM 428 50mm Rear sprocket 24T … $25.00
    1 USED – SKM 428 50mm Rear sprocket 25T … $25.00
    1 USED – SKM 428 50mm Rear sprocket 27T … $25.00
    1 NEW – 428 CR125 Front 17T…$10.00
    1 NEW – 428 YZ125 Front 17T…$10.00
    2 New – TM Clutch Pack – Fibers, ALuminum floaters, springs…$80.00
    1 Used – TM Clutch Pack – No Springs $30.00
    1 New – TM Clutch Pack – No Springs $65.00
    4 New – OEM TM Steel Clutch Plate $5.00
    1 New – TM Gasket Kit #05612…$20.00
    1 New – SwedeTech TM K9 Reeds only..$60.00
    1 New – SwedeTech TM K9 Reed set with stiffeners…$70.00
    1 New – TM K9 Reed Set with Stiffeners (Carbon Fiber)$70.00
    1 Used – SwedeTech TM K9 Reed set $40.00
    1 Used – TM ICC 15t $15.00
    2 Used – TM ICC 16t $15.00
    3 Used – TM ICC 17T $15.00
    1 New – TM ICC 19T $15.00
    1 New – Thermostat Righetti Ridolfi #K696N
    2 New – Speed Concepts Engine Monitors SCMM-1 – $100.00
    http://www.ebay.com/usr/extrakartparts
    My personal account and my personal opinion. This is not the opinion or commentary of my employer, or any sponsors, current and future, wishing to expand their advertising to a loyal customer base.
  • #24593
    Jason Berry
    Engine monitors sold —
