Home Forums Tech Talk Update bars and pods on old Arrow chassis
This topic contains 1 reply, has 2 voices, and was last updated by  Walt Gifford 4 years, 10 months ago.
  • #19966
    Jay
    I had a weld fail on a stock side bar support on my antique Arrow AX-8 this past weekend. I’d really like to fit a set of one piece, weld-free bars and new side pods to my chassis–if it can be done while using the stock mounts on my chassis. Anyone happen to have done this?
  • #19968
    If the mounting tubes are flat it would be fairly easy to retro fit a generic set of flat side bars. You will probably have to do some chop cut reweld to the new side rails but you’ll be working in 2 dimensions. If one or both of the mounting tubes angle up it will be near impossible to bend someone elses side bars to fit. In that case I would cut them off the frame and re-weld them flat to match up to something that’s commonly available.
