Home Forums Shifter Karts trouble with front hubs
This topic contains 7 replies, has 3 voices, and was last updated by  William Martin 3 years ago.
  • #53946
    Bill Schmidt
    I bought a 2008 Intrepid shifter and am still sorting it all out. My previous kart was an antique Trackmagic (American made and fittings). I want to narrow the front track just a little. The front hubs slide onto the secondary hub (that contains the bearings. The hub slides inward just fine, until it hits the front wheel. It looks to me like the wheel should slide onto the hub. I think the hubs are 40mm, but the wheels look like the pilot hole is about 38mm? The wheels are Douglas M series. Am I doing something wrong, or is this a built in safety net?
  • #53952
    James O’Brien
    Do you have the plastic outer rings still on?
    www.eshifterkart.com
  • #53953
    Bill Schmidt
    I haven’t seen any plastic rings. Where would they be if I had them?
    • #53957
      James O’Brien
      Yeah the end of your inner hub, like a plastic spacer, they are usually red on the Intrepids. But that doesn’t sound like it. What line on your inner hub are you trying to get to?
  • #53972
    Bill Schmidt
    There are 9 lines on the hub. I am trying to get to the last one. Need about 3/4″ more movement to get there. The outer hub will go all the way to where I want it to go, but not when the wheel is bolted to it.
  • #54012
    James O’Brien
    Anyone remember guys cutting off the ends of their hubs about that much to narrow the front?
  • #54065
    Bill Schmidt
    Well, it turns out that my friend Alan Sheidler looked at the kart today and he said the hubs are 40mm and the wheels are 35mm, or close to it. So basically someone before me bought the wrong wheels. I am the 3rd owner of the kart.
    • #54067
      William Martin
      Sounds like you need to find “normal” 40mm wheels, what you have sounds like some CRG thing. At any rate, the wheel registers on the center hole, not the bolt holes, so it will not be happy even if you had the adjustment range you want. Running out of true is as bad as out of balance…only maybe worse!
      Bill M.
