Home Forums General Karting Discussion Torque Wrench
This topic contains 2 replies, has 3 voices, and was last updated by  Matt Martin 9 months, 3 weeks ago.
  • #81286
    William Weiler
    I notice Briggs says to check head bolt torques every race but my torque wrench is for automotive use and doesn’t do that small of a torque. I see these small 1/4″ drive torque wrenches for bicycles. They are many different prices points. Is there a torque wrench that people like?
    TonyKart 401s LO206
    Masters Class
    Morgan Hill, CA
    #81291
    Take the spec you need for the head bolts and any other bolts you might want to torque (like maybe a spark plug), and search the internet. I use a 3/8’s drive one that was left over from work. It’s scale is in inch/pounds. Recommend the type that you set the torque value by turning the end of the handle and the head clicks when the value is reached. Wouldn’t go over $100. A $50 one should be just fine. I saw a range in prices from $19 to $400. You don’t need the $400 variety and I’d stay away from the cheap beam type that has a pointer and a scale to read the torque values off of.
    #81297
    Matt Martin
    get a beam/blade type – they’re cheap and accurate.
