Home Forums Chassis & Handling TonyKart steering shaft collars
This topic contains 2 replies, has 3 voices, and was last updated by  tony zambos 4 months, 3 weeks ago.
  • #85774
    William Weiler
    I noticed my used kart doesn’t have the steering shaft collars around the upper plastic bushing. It seems like pulling on the wheel would cause the uniball to come out of it’s spot without the collars, but it hasn’t happened. Do people normally just leave these off?
    TonyKart 401s LO206
    Masters Class
    Morgan Hill, CA
    #85879
    William Martin
    There is a snap ring holding the bearing in place. Unless you be Godzilla, you probably can’t pull hard enough to pop it out!
    #86506
    There is a steering shaft locking collar that’s available.
    https://cometkartsales.com/I.-0115.00-Steering-Column-Locking-Collar.html
