--> Tonykart rear brakes wont self adjust – eKartingNews
Home Forums Tech Talk Tonykart rear brakes wont self adjust
This topic contains 5 replies, has 3 voices, and was last updated by  Craig Whitfield 3 years, 12 months ago.
  • #29371
    Craig Whitfield
    Hello.
    I have a 14 evk kz tonykart and while I was changing a axle I went and mistakenly pushed the pads into the calipers to allow room for the brake disc. (I did this because I accidentally pulled the brake on)
    Now It won’t let me bleed them at all and every time I do bleed them the Pistons and pads only move slightly then go back in. The pistons are not far away from being flush with the caliper.
    I plan on driving Saturday so I’m hoping I haven’t totally destroyed the rear brakes. Fronts are perfect but I can not get the pads on the rear anywhere near the disc.
    Any help would be appreciated alot.
    Craig whitfield
  • #29379
    Steen Carstensen
    Make sure the arm on the master cylinder returns ALL the way back against the body. Best way is to disconnect the balance bar at the MC arm, then bleed the brakes. I use a “Mighty Vac” attached by a piece of fuel line to the bleeder nipple.
  • #29380
    Mark Dismore Jr.
    Did you remove the two big reservoir caps and the rubber seal? Sounds like it is vacuum locked.
    • #29388
      Craig Whitfield
      I removed the reservoir caps yes but not the rubber seals??? The rubber seals on the lids or where the actual bleeding tool screws in?
      I hope it’s something stupid I’m doing and is an easy fix. The pistons on the rear definitely seem vacuum locked because both always return to same position.
  • #29390
    Mark Dismore Jr.
    The seals under the reservoir caps. They can vacuum down so even if you remove the caps the system is still sealed until you pull them off.
    I’d pull the caps and rubber seals, pump the brakes a few times and see if that fixes your problem. Personally I like to bleed the system with a bleed tower from the master cylinder.
  • #29391
    Craig Whitfield
    Guys it’s fixed. I removed the stop at the pedal to allow the arm to go fully back like steen said and I then noticed the left side moving then eventually the right side moved to.
    Thanks guys I really appreciate the time you took to answer the questions.
    Now I just need to even them out.
    Thanks again
    Craig whitfield
