Home Forums Chassis & Handling TonyKart brakes
This topic contains 4 replies, has 3 voices, and was last updated by  William Weiler 1 month ago.
  • #89324
    William Weiler
    My brakes seem to not have feel or easy communication about what they are doing on the track. To make them better I asked some racers if they change the brake fluid. One guy said he never bleeds them. Another 2-cycle guy says he bleeds them after every race. Since the OTK bleeder tool is like $80 on fastech, do you think it is worth getting? Pads see bewildering as well, as far what to get next.
    TonyKart 401s LO206
    Masters Class
    Morgan Hill, CA
    #89330
    The pedal feel on the OTK brakes is definitely something to get used to, but I’ve found once I got a feel for them, I really liked how I was able to modulate the pedal compared to past karts I drove.
    I would definitely recommend having a bleeder on hand. It’s a nice tool to have. I know some drivers that bleed the brakes once a day. I never touch them except to change pads, unless there’s an actual problem with them. Seems to be a mental thing for some drivers.
    If you want a different feel in the brakes, they do make a few different levels of hardness for compounds on the pads. OTK sells a few different compounds and there are some aftermarket brands like Frixa who also sell some harder or softer pads.
    #89375
    Tom Jazwiecki
    Brake bleeder is a great idea. You can make your own with a plastic syringe and a rubber tip, then you can force bleed in one step. Also, make sure both pistons move freely in the caliper housing. If not, take the caliper down, clean it thoroghly, buy a rebuild kit, and bleed it.
    #89376
    Tom Jazwiecki
    Ferodo makes pads as well, but in my experience, though, nothing works as well as the OTK medium pad. They are pricey, but had a great balance between stopping power and modulation.
    #89471
    William Weiler
    I checked online for medium pads. Even on the TonyKart site it is weird, with similarly identical entries for pads with identical part numbers. Does anyone have a part number for a medium pad? No where do I even see the words “hard” , “Medium” or “Soft”.
    TonyKart 401s LO206
    Masters Class
    Morgan Hill, CA
