Home Forums Shifter Karts Tony Kart What have I got?
This topic contains 4 replies, has 3 voices, and was last updated by  James O’Brien 2 years, 7 months ago.
  • #51963
    Derek Lynch
    Hi all,
    I’m new to karting and just picked up a used Tony Kart. I’m told it’s a 2006. The engine was built by SharkShifter in Oregon and has about 6 hours on it.
    I’m trying to find out if it’s a “mod” engine or stock.
    I’m also trying to sort out some fueling issues but I think I’m on the right track… I took it to my local track for a shakedown but seemed to not run great on the top end. After investigating, I found the PO had a 205 main jet which seems way to big from my research and should have maybe a 175. The pilot is a 55. I haven’t looked at the needle yet.
    I have a photo but how do I upload that?
    Any help is appreciated!
    Derek Lynch
    Sanford Mitz
    Some indicators of Mod 125 are:
    Non-OEM ignition
    “O” ring head
    Spacer between the cylinder and the block
    V Force Reed Cage
    Not definitive, but upload some pictures
    Derek Lynch
    Thanks a bunch… It has two base gaskets (cylinder to case) and no apparent head gasket so I called SharkShifter and verified it is indeed a mod engine. I also got some advice on jetting for my area to start with.
    Do I use something like photo bucket to upload photos?
    James O’Brien
    That had a 205 Derek? Wow, that’s a ton man. Even for a MOD. No wonder you were having problems. Hope you got it narrowed down.
