Home Forums General Karting Discussion Tony Kart kid kart pedal extenders question
This topic contains 1 reply, has 2 voices, and was last updated by  Troy Berry 2 years, 10 months ago.
  • #58705
    Steven Kovalovsky
    I just bought my son a 2014 Tony Kart kid kart. He is still quite small, and needs pedal extenders to reach the pedals comfortably. The problem now is that Tony Kart has a completely different way of constructing their (throttle/brake) assemble. The round bar used for the pedal is a 10mm solid round bar, as apposed to the usual larger diameter hollow bar. On top of that, it is also bent at a 90 degree angle at the ends. So you cant even use a simple slide on extender. Is there any particular solution for this problem? Tony Kart kid kart pedal assembly
  • #58796
    Troy Berry
    Maybe something like this will work?http://www.accelerationkarting.com/pedalextensions.aspx
    Might be able to slide them past the bend and use a sleeve to make up the difference?
    "The Art is in the details"
    BirelArt AM29 LO206
    Intrepid Cruiser KA 100
