Home Forums Chassis & Handling Tony Kart front end question
This topic contains 5 replies, has 3 voices, and was last updated by  TJ Koyen 1 year, 9 months ago.
  • #66371
    Nicholas Bruno
    I have a Tony Kart with the multi-hole adjusters ONLY at on the top of the spindle, with a neutral, non-adjustable pill in the bottom. The way I figure, the front end settings in this configuration should be:
    Arrow pointing forward: Most caster, middle camber
    Arrow pointing inward: Middle caster, least (most negative) camber
    Arrow pointing rearward: Least caster, middle camber
    Arrow pointing outward: Middle caster, most (positive) camber.
    Would this be correct? And also, what would a baseline of these settings be?
    Nick
    #66374
    FREDDY SANDOVAL
    I don’t know why it doesn’t have adjusters at the bottom, but if I’m correct “N” Neutral position on those is Arrow pointing forward, and counting 5 holes on any direction, left or right.
    What year and model is this Tony Kart?
    #66376
    Nicholas Bruno
    https://cometkartsales.com/images/D/0212.d0.jpg
    This is the bushing on the bottom. This is a 2012 EVRR
    So you’re saying arrow forward is neutral camber and caster?
    #66381
    It can be confusing. With a neutral pill in the bottom the settings on the top pill are as follows:
    Arrow forward = most caster, neutral camber (top of kingpin tilted back)
    Arrow backward = least caster, neutral camber (top of kingpin tilted forward)
    Arrow inward = neutral caster, most positive camber (top of kingpin tilted outward)
    Arrow outward = neutral caster, most negative camber (top of kingpin tilted inward)
    The baseline setting from the factory would be full neutral, meaning a neutral pill top and bottom, or two adjustable pills, one on top and one on bottom with each arrow facing the same direction.
    #66427
    Nicholas Bruno
    Thanks TJ. Unfortunatly it looks like there is not real “neutral” setting for both camber and caster.
    #66429
    Not if you have one neutral pill and one adjustable. You need either two adjustable pills or two neutral pills.
