Home Forums General Karting Discussion Tony Kart EVX set up details?
This topic contains 4 replies, has 3 voices, and was last updated by  Rod Hawkins 4 years, 1 month ago.
  • #26674
    Rod Hawkins
    Anyone happen to have the tony evx set up specs? I know I found them once but can’t seem to find them. Just bought a used one for a great price. Would love to have the numbers as a starting baseline and adjust from there. Seems like for some reason they are very difficult to find.
    Tia.
  • #26709
    Clark Hadden
    Build the Chassis mount your seat to your height spec. Put your choice of engine on Chassis Sprocket, Chain and tires. Add fuel/mix. Maybe a little Caster and don’t touch the chassis. Just drive! The sweet spot is a mile long…
  • #26984
    Mick Gabriel
    Seat setup is critical PM me.
  • #26991
    Rod Hawkins
    I got the seat placement dialed in by someone that is very familiar with setting them up. He just didn’t have time to set up the front track and I was just looking for a hard copy of the baseline setup so I know where to go when I adjust certain things.
  • #26854
    Rod Hawkins
    Thanks,  found some info online, but it wasn’t easy (this is for an EVXX, which is close and different tires)
    http://www.stablekarting.com.au/news/detail.asp?iNews=8936&iType=100
    Set Up sheet – Kart Model: Tony Racer EVXX
    Condition: Normal Grip Circuits
    Date: 2010
    Tyre : MG Yellow Tyre
    Rear Track: Tony Kart wheels, rim to rim, o/side to o/side; 1385mm (1390mm max.)
    Usually 1385 and leave
    Front Track: Tony Kart wheels,
    Top of inside front rim to centre of kingpin —- 125 mm_135 mm (start at 130 mm)
    Rear Bar: out
    Front bar: in and flat (we also have three types of round torsion bars)
    Rear ride height: STD, i.e. chassis middle
    Caster: add caster if circuit is twisty/tight (can be driver dependant)
    MG tyres normally require additional caster,
    Rear wheel hubs: standard i.e. 85mm
    Rear axle: Tony type N (H is harder, P or E is softer)
    Front crash bar: Usually tight
    Front lower crash bar: tight
    Front ride height: STD i.e. middle of c section
    Seat stays: one per side (for more rear grip add additional stay to brake side)
    Side pods: loose
    Tyre pressure: 10_10.5 psi
    Front Hubs: 80mm long (std on Racer EVXX)
    Toe out: 2mm total
    Wheel Type: Tony Kart magnesium wheels all round
    This set up sheet is for circuit that offer normal grip levels for the duration of the event.
    It is not intended for a Green circuit or a circuit that has worn out stones.
