Home Forums Shifter Karts Tony Kart Bearing Sizes?
This topic contains 4 replies, has 2 voices, and was last updated by  Adam Gorrell 1 year, 4 months ago.
  • #73086
    Adam Gorrell
    <p style=”text-align: center;”>How’s it going everyone? I was wondering if anyone happened to know where I can find all the sizes of all the bearings on a Tony Kart? I’ve got a couple 09 Tony Kart 125 Shifters and a 09 Tony Kart Rotax Senior Kart that I am looking to swap all the bearings out on and was hoping to find a detailed list of part numbers or at least dimensions so I can get them ordered.</p>
    <p style=”text-align: center;”></p>
    <p style=”text-align: center;”>Any help would be greatly appreciated.</p>
    <p style=”text-align: center;”>Adam</p>
    #73098
    Matt Martin
    grab a pair of calipers and measure.
    I’d assume the rear axle uses 80mm x 50mm or 90mm x 50mm
    Does the kart use 17mm or 25mm front spindles?
    #73100
    Adam Gorrell
    grab a pair of calipers and measure. I’d assume the rear axle uses 80mm x 50mm or 90mm x 50mm Does the kart use 17mm or 25mm front spindles?
    I’m definitely gonna grab a pair and get to measuring but figured I’d ask if there was already a list with part numbers or an exploded view of the kart with all part numbers.
    #73101
    Matt Martin
    If it uses the older style spindles (8mm king pin), it’s likely 8mm x 22mm, if it’s newer (10mm king pin) it would be 10mm x 26mm bearing.
    The wheel bearings would be 17 x 35mm if it’s a 17mm spindle; or 25 x 42 x 12mm on the newer, 25mm spindles.
    Then, there’s just the uniball on the steering shaft.
    #73102
    Adam Gorrell
    If it uses the older style spindles (8mm king pin), it’s likely 8mm x 22mm, if it’s newer (10mm king pin) it would be 10mm x 26mm bearing. The wheel bearings would be 17 x 35mm if it’s a 17mm spindle; or 25 x 42 x 12mm on the newer, 25mm spindles. Then, there’s just the uniball on the steering shaft.
    Awesome. Thank you so much for your help. Much appreciated.
