Home Forums General Karting Discussion Tire's Leaking Air
This topic contains 4 replies, has 5 voices, and was last updated by  Marshall Martin 3 years, 1 month ago.
  • #48512
    Gene Rivera
    I have a handful of magnesium wheels, that leak air, at the bead (tire-sidewall/wheel connection). They are very slow leaks, but air leaks, none the less. I have verified that they do not leak from the beadlock screws or the Valve stem.  Wheels are in decent shape otherwise, and wish to salvage and continue to use them.
    Does anyone have a “trick up their sleeve” that I can use to Stop these leaks 100%, please?
    Thank you
  • #48544
    Jim Derrig
    A can of Flat Fix.  Probably don’t need much in each tire.
  • #48548
    You know that most racing tires leak air right through the rubber right? If they hold air for an hour that’s my minimum standard for sprint racing. Have you tried wire brushing or using 150 grit sandpaper. If you have some way to spin the wheel it makes it easy. You could also try a very thin layer of epoxy or JB weld.
  • #48557
    Curtis Cooksey
    The beads can get torn up mounting and dismounting tires. If I have one with a bead that is leaking I will debead the tire and rub a little rtv sealant around the bead. It has always worked for me.
  • #48567
    Marshall Martin
    This will sound very strange but I saw it work.   Down dish soap on the bead, don’t think I am crazy (as I did the guy who told me) until you try it.
    Marshall Martin
    -marshall@lsrmotorsports.com
    -www.lsrmotorsports.com
