Home Forums Tech Talk Tire's Leaking Air
This topic contains 3 replies, has 4 voices, and was last updated by  Greg Cavouras 2 years, 8 months ago.
  • #48515
    Gene Rivera
    I have a handful of magnesium wheels, that leak air, at the bead (tire-sidewall/wheel connection). They are very slow leaks, but air leaks, none the less. I have verified that they do not leak from the beadlock screws or the Valve stem.  Wheels are in decent shape otherwise, and wish to salvage and continue to use them.
    Does anyone have a “trick up their sleeve” that I can use to Stop these leaks 100%, please?
    Thank you
    Sean Swisz
    I’ve had the same problem with multiple sets of wheel. I clean them with Simple Green to get most of the crud off, then spray some Brake Clean on a rag and scrubbed both sides of the wheel lip.
    I know you said you confirmed that they are not leaking from the bead locks, but it’s a good idea to change this seals. I changed them last year and they were already cracked and dry rotted again at the start of this season. Also a good idea to run tap & die kit through the wheels and bead lock screws. Hopefully that helps.
    Tony Kart / Leopard
    John Mulvihill
    Common problem with automotive wheels, too.    Tire shops have a black goo that seals tires to the rims, maybe you can bum some from the local tire shop.
    Greg Cavouras
    This is a very common problem with 6″ super kart wheels and tires…. go to your local auto parts store and buy some bead sealant.  Clean the bead area thoroughly, and after you mount your tires but before you inflate them to set them, apply a thin film around the bead where the tire meets the rim and your leaks will stop.
