Home Forums General Karting Discussion Tire Pressure Gauge Rec.
This topic contains 7 replies, has 5 voices, and was last updated by  Tim Koyen 4 years, 7 months ago.
  • #20263
    Todd Kageals
    Guys,
    I need a new tire pressure gauge.  Here’s what I am looking for:
    1. Accurate/Repeatable
    2. Durable (dropped my last one ONCE and it quit working correctly.
    3. Cost?  Well…..I don’t want to pay $300 for one!
    4. I’d like to be able to use it on the karts and my cars so I need a range up to about 60 lbs (at least 45).
    Anyone got a recommendation?
    Todd
  • #20267
    Ray Mcik
    this is the compressor i have mounted in my trailer, works well and you can hand carry or leave it mounted with 20 ft coiled  hose .
    I bought it at Walmart for $50 bucks about 8 years ago and has served me well, has just enough air to seat new tires on the rims..
    Campbell Hausfeld  2 Gallon Wall-Mountable Air Compressor
    http://www.amazon.com/Campbell-Hausfeld-FP205299AV-Wall-Mountable-Compressor/dp/B000642GF2/ref=cm_cr_pr_pb_t
  • #20272
    patrick j slattery
    I use a Longacre digital which I used for Karts and My Spec Miata,  its a 0-100 psi, very accurate and measures in tenth of a pound.  I paid about $100 and will buy another if I ever need one.  I have used this for 4 years already
  • #20275
    Todd Kageals
    Patrick,
    Which model Longacre.  I saw one on amazon but the reviews were not very good.
  • #20290
    patrick j slattery
    Longacre 53000, slightly different than mine as it is 0-60 psi
  • #20665
    John Cleveland
    Todd, found this one to be accurate and didn’t break the bank.
    http://www.jegs.com/i/JEGS+Performance+Products/555/65035/10002/-1
  • #20722
    Tim Koyen
    I had a Longacre digital one for awhile, until I realized it was 2 lbs off, then it hit the junk pile.  One of the nicest I’ve ever used is the Intercomp digital, but it was pretty pricey at nearly $300.  The one I use now, and that is quickly becoming the standard with tuners, is the Hi Prema, made by Prisma.  KartSport distributes them and they are generally around $200.  It has a 76lb max, with .1 lb resolution and a 4 tire memory.
    KartLift Kart Stands
    DeepSeat Kart Seats
    877-777-8020
  • #20265
    Ray Mcik
    I have this one and love it, although it is hooked to my air compressor ,
    I can air up the tire then bleed off the air to get the exact pressure I want .
    glows in the dark with a big number  dial indicator for old eyes…
    http://www.intercomp-racing.com/category/Air_Pressure_Gauges.cfm?PageNum_GetItems=3
    http://www.ebay.com/itm/New-Intercomp-Fill-Bleed-Read-Tire-Pressure-Gauge-/261377087422
    http://www.amazon.com/INT-360086-Intercomp-psi-Fill-Read-4-GlowDial/dp/B004QQ0HFC
