--> Tire Changing – ekartingnews
Home Forums General Karting Discussion Tire Changing
This topic contains 13 replies, has 9 voices, and was last updated by  Walt Gifford 11 months, 4 weeks ago.
  • #81807
    William Weiler
    I just got my TonyKart/LO206. I am going to practice at MBK Saturday and race the next weekend at KPX in Fresno. I see I need Evinco Blues for KPX. I bought a bead breaker from Fastech Racing and I watched youtube videos on tire changing, but I’ve gotten different advice. I have been told I need a tire wrap for seating to keep it from stretching, and that I should get tire irons. I really want to know what is the easiest way.
  • #81815
    I’ve always used a cloth tire wrap, made by Exotic Toy Builder. It’s probably not available any more. The new ones all seem to be metal. You’ll see many people not used them. I would use one. You’ll need something to lub the tire and rim to bead up the tire. Dawn dish soap works. If you’ve seen the You Tube videos of guys mounting up tires with their bare hands, forget it, you won’t be able to. Get a tire Pryr kit.
  • #81816
    Kevin Ferrara
    I mounted one set of tires with my bare hands and swore it off forever. What eventually helped, after going through two bottles of windex, was leaving the tires out in the sun for a few hours to soften up.
  • #81818
    William Weiler
    Looks like the Pryr kit is $170. I kind of wanted to slow down the money flying out of my wallet, but I don’t want to be cheap and suffer (been there). Is it really worth it? Are there options?
  • #81820
    William Weiler
    I went to buy a tire Pryr look-alike and I had to choose the one for 5″ or 6″ wheels. To find out, I checked my builder’s sheet and I have KG Aluminum 170mm and 140mm wheels. I went to look this up and a website says there is no company called KG. The wheels I see on Kart retail websites don’t come in those widths either. Kind of makes me feel a little concerned I can’t replace a wheel if it gets damaged.
  • #81823
    KG is indeed a well-known karting company, this is their website: http://www.kgkarting.it/?lang=en
    The 170mm refers to the width and the 5″ or 6″ they are asking for is the diameter, which is the standard diameters for karting wheels. For sprint karting (like you’re doing), 5″ is the regulation size.
    For a tire changing device I recommend the KartLift tire changer. Cheap, easy, effective. http://kartlift.com/e-store/index.php?route=product/product&product_id=88
  • #81824
    William,
    The wheel sizes you mentioned seem a little off, but then I have no idea as to what size wheels are used on a 206. 5″ wheels are the most common. Only occasionally have I seen 6″ on endure karts. Look at the tire size on the tire. Example: a 7.10 x 5 would indicate a 5″ rim.
    For the time being, if there is a shop or a kind fellow racer at the track, ask if they will mount up your tires. And watch closely. Mounting tires is not that hard if it’s warm out. But it does take some technique.
  • #81826
    Did a little looking around found the tire sizes for LO206 are 4.60 and 6.00, both are on 5″ rims. So your rim sizes seem OK.
  • #81830
    William Weiler
    TJ – your link is to an accessory. I see the tire changer though and it looks good.
  • #81927
    John Kwong
    There are certainly some great karting products out there but for the budget conscious karter sometimes you need to be innovative.  The biggest issue I found was mastering the technique of changing tires with your bare hands.  I always needed that 3rd hand or more leverage.  Our temperature during racing season in Canada is rarely hot and a warm tire is always easier to change.  What I use is a length of 3/8″ ready rod, 2 flange nuts and 2 pieces of 1″ square aluminum tubing cut to about 4″ long.  I use this contraption to mount the wheel to the work bench via a hole in the work bench.  This way I can get enough leverage to use the techniques you see on most of the tire changing videos.  I have been using this tool I built for over 20 years now.  It is simple, cheap and easy to haul in my toolbox.
    Homemade Kart Tire Changer
    For myself, I don’t like using water when mounting a tire as it will cause the tire to heat differently when being used because of the water left inside.  I use Gojo smooth hand cleaner (non-grit) as a tire lube as it evaporates inside the tire.
    John K
  • #81976
    Bruce Peck
    I’ve used one of these tools for 20+ years.  Mine is mounted to my workbench but I’ve seen people mount to a bar you can put into a trailer hitch on your truck, etc.  Does 5″ or 6″ tires.  Easy to get them on and off once the bead is broken.  Oh, and I use old fashioned KY jelly for mounting.  Slick as snot.
    http://www.bmikarts.com/Standard-Tire-Changer-Tool-For-5-or-6-Wheels_p_2561.html?gclid=EAIaIQobChMI29mKyP2E1AIVlFcNCh3t-gLeEAQYASABEgISqfD_BwE
  • #81977
    FREDDY SANDOVAL
    Some times being cheap can get pretty expensive real quick
    My wrists and joints are not a big fan of doing tires by hand, although I have done this many times, still hate it.
    This is the best tire you can buy for the budget, and will pay for itself very soon. Just buy one of these and you will never look back, not to mention it will only take you 5 minutes to dismount old ones and re install new ones.
    It sounds expensive, but when you use it several times, you’ll be glad you bought it, and it’s totally worth every penny.
    http://www.empirekarts.com/tdc-tire-changing-tool
  • #81995
    Michael Beckrest
    William,
    The manual tire changer tool by Righetti Ridolfi is my favorite… Huge time saver. Check it out: manual-tire-changer
  • #82098
    I bought one of these, best money I ever spent.
    http://www.accelerationkarting.com/turbotirechanger.aspx
