Home Forums Shifter Karts Tilly on a YZ?
This topic contains 6 replies, has 4 voices, and was last updated by  Carl Beavers 4 years, 6 months ago.
  • #3902
    Ted Hamilton
    Anyone run a Tilly on their 125 shifter? What was your experience? i have a manifold made up for my IBEA L3 to fit on a YZ125 (’01) but am unsure if that’s a good move or not….Looking to tune needles on the fly.
    ~Ted
    #4044
    Riley Will
    Do t do it unless you plan to leave it in one gear. Been there, dun That!
    #4097
    Ted Hamilton
    Was considering putting it on my winged outlaw, which usually is one gear, maybe 2 on the start… For the sprint kart I’d leave the stock mx style carby… 🙂
    #4104
    Riley Will
    It will work very well in that application. However, dual carbs will work waaaaay better:)
    #4446
    Robert Horvath
    Yes Ted,
    I run a Tilly HW 12 34mm Carb on one of my Honda CR125s and a Mikuni SNB 38mm on my other Honda CR125 shifter.
    Both carbs perform very well with the smaller Tilly doing a better job on short tracks and the bigger Mikuni doing a better job on long tracks as would be expected !
    Or for another take on “ON THE FLY CARB AJUSTING” look at my utube here :
    Tilly 34mm HW 12 Carb
    Mikuni SNB 38mm Carb
    UPDATE :
    FYI Shifter Go Kart Guys,
    For the open/modified
    class of Honda CR125 Shifters.
    The very short fuel path direct fit Honda CR125 Shifter intake manifold for 38mm 2 flange bolt types of carburetors is all done .
    It has a 11 degree right rotation angle
    to to clear the kick start bump ( Carbs like the externally adjustable Mikuni 38mm Carbs work really well )
    No more rubber boots with right angle turns to disturb the fuel flow !
    And even a more perfect fit when used in conjunction with the V-Force 3 Reed Cage box .
    I’m getting this experimental test carb fitted up to the CR125 Honda.
    Mikuni Super Butterfly Type SBN38mm Diaphragm Pump Carburetor
    No jets to change ever (well almost never) as it has easy to get to externally adjustable low & high speed mixture screws just like the Vortex RoK-tt carb only a much bigger bore (38mm) to fit the CR125 Honda engine and the fuel pump is built right in too.
    I’m getting tired of always taking off the carb to change the high & low speed pilot jets and I don’t care for float types of carbs either.
    These are one of the best performing and easy tuning carburators that money can buy.
    see below:
    Honda Cr125 intake manifold
    intake and carb
    Intake and carb together
    Thank You
    Bob
    Robert Horvath
    W352N6446 Road J
    Oconomowoc Wi 53066 U.S.A.
    rhorvath4@wi.rr.com
    #5063
    Ted Hamilton
    Thanks, Robert… I may be interested in the Super BN 38 conversion…
    #5334
    Carl Beavers
    Great Job! Looking forward to your testing report.
